The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (moparguy, Napco Man, 3800GUY, Hambone, 53 green 1- ton, 1 invisible), 95 guests, and 2 robots.
Forums60
Topics127,472
Posts1,031,730
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 35 of 39 1 2 33 34 35 36 37 38 39
Re: 1948 Thriftmaster 3/4 ton - Poncho engine swap
Goach2 #1438353 Sun Jan 23 2022 01:32 AM
Goach2 Offline OP
Ok, moved the oil discussion to here: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1438297.html#Post1438297
Going to move on and changed out the front bearing in the transmission.
Just to confirm, I have decent looking synchro's for first gear, but they aren't brass. I was told to just leave these in place since 1st is rarely used:
[img]https://www.stovebolt.com/ubbthread...umber/38962/filename/20220122_202733.jpg[/img]
Also, I just noticed the chatter on these gears, is it a big deal?
[img]https://www.stovebolt.com/ubbthread...umber/38963/filename/20220122_202721.jpg[/img]
1948 Chevrolet Thriftmaster 3/4 Ton
There are only 10 types of people in this world, those who can read binary and those who can't.
Goach2 #1438365 Sun Jan 23 2022 03:13 AM
That sure looks like brass to me. ohwell
If you're talking about the sawtooth pattern between the gear clutch teeth and the synchronizer, I believe that's normal. Everything else looks good to me.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Goach2 #1438369 Sun Jan 23 2022 03:26 AM
Goach2 Offline OP
Sorry, to clarify, these are the original brass synchro's and I have a spare trans that has a donor set in great shape, but those are not brass. I was told I should keep the original brass regardless.
For the 2nd synchro, I was referring to what I circled here, is this supposed to look like that?
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/38965/filename/Gears.jpg[/img]
Finally, I tore into the trans tonight and the replacement bearings for the front have the correct dimensions, but less bearings in them. Is this a problem?
[img]https://www.stovebolt.com/ubbthread...umber/38966/filename/20220122_211710.jpg[/img]
Goach2 #1438376 Sun Jan 23 2022 04:27 AM
Yes, that's what I thought you were referring to (what you circled). I think it' a remnant of the machining of the gear, and nothing to worry about.
Goach2 #1438396 Sun Jan 23 2022 02:17 PM
Goach2 Offline OP
I was concerned because it doesn't have a consistant pattern like a machine would leave. I'm going to check my spare...
Goach2 #1438401 Sun Jan 23 2022 02:53 PM
Goach2 Offline OP
Spare trans does not have the chatter marks:
[img]https://www.stovebolt.com/ubbthread...umber/38974/filename/20220123_094855.jpg[/img]
Goach2 #1438415 Sun Jan 23 2022 04:12 PM
Are you able to get the chip collected at the bottom of the transmission out to see if there are any chips trapped in it .photo from Denny Graham site.
kevinski 1954 GMC 9300 Welcome to the virtual Garage [stovebolt.com]
Goach2 #1438439 Sun Jan 23 2022 05:26 PM
Goach2 Offline OP
Still cleaning, but found this in the bottom:
[img]https://www.stovebolt.com/ubbthread...umber/38983/filename/20220123_122238.jpg[/img]
Also missing a key?
[img]https://www.stovebolt.com/ubbthread...umber/38984/filename/20220123_122304.jpg[/img]
Haven't found it yet, feels like this is a pretty crucial part...
Goach2 #1438610 Mon Jan 24 2022 07:57 PM
Goach2 Offline OP
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1438568.html#Post1438568
Think I've got a plan now. Basically, front half of the gear/shaft assembly from newer donor trans and original to the rear. Got to clean it all up, paint and reassemble. I will have some questions on the gaskets shortly...
Goach2 #1438791 Tue Jan 25 2022 11:55 PM
Goach2 Offline OP
Kid got me sidetracked with his project:
[img]https://www.stovebolt.com/ubbthread...umber/39056/filename/20220125_172402.jpg[/img]
In the meantime, starting to plan for fender reassembly. I know not everyone has the center mount under the rad, but mine is about 1-5/16" unbolted:
[img]https://www.stovebolt.com/ubbthread...umber/39057/filename/20220125_184548.jpg[/img]
This is a new piece, it used to have about 5/8" of steel wedged in there. I'm assuming everything is going to align completely different now, than it did previously. I was thinking about starting with the hood alignment that"s in the tech articles first, then piecing it all together loosely until by some magic I can close and latch it. Make sense?
Moderated by  HandyAndy
