The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Rsqwhite, Ridgeback, Dakotabolt, Shakey61, truckcamper43, Bill Hanlon), 110 guests, and 3 robots.
Forums60
Topics127,470
Posts1,031,724
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: 1958 panel
Guitplayer #1425556 Thu Sep 30 2021 08:06 PM
Tank is out. Had about 5 gallons of 40 years old fuel in it.
I needs the inside cleaned . Are there restoring methods?
1958 3100 Apache 327 engine
1958 3100 Apache Panel 327 engine
Re: 1958 panel
Guitplayer #1425561 Thu Sep 30 2021 08:24 PM
https://www.carburetor-blog.com/knowledge-base/cleaning-your-gas-tank/
I used clean rounded pea stone followed by a few rinses with kerosene.
Maybe people will post whether or not to coat a clean inside?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 1958 panel
Guitplayer #1425567 Thu Sep 30 2021 08:52 PM
Sir Searchalot
Nice tank if no leaks.
All kinds of ideas to clean inside. From acetone to kerosene to kits. Depends on how bad it is. Gum is one thing, rust is another. I've seen a test for the rust part and Evaporust was the winner.
No known sender replacement, so be careful when removing/cleaning the sender. If the wiper inside the rheostat is still good, other parts are available to restore sender.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
I recommend invoking MIL-T-FP41c when machining and fabricating
I used to think beer was bad for me, so I gave up thinking.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
Re: 1958 panel
Guitplayer #1425568 Thu Sep 30 2021 09:09 PM
I figure to start with some vinegar and baking soda. Then back in the late 90s
I remember using POR product for tanks.
Yeah , that is a funky sending unit.
I use one like this is my other 58 with the under bed tank. They make different heights and
ohms.
Do you know if they make bed rails for this panel? Appears to be the original wood in good shape.
Re: 1958 panel
Guitplayer #1425599 Fri Oct 01 2021 01:31 AM
....use the POR15 on my 52 panel and used their kit in my '37 gas tank 22 years ago. Still going strong. I love the stuff. I did have to grind my chassis where the grounds go though. Tough stuff.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Re: 1958 panel
bartamos #1425717 Sat Oct 02 2021 04:00 PM
Yeah, that sending unit is unique. I think its OK. Long as the stat works.
Still had the filter and float on it. I took those off. Tube was clogged. No leaks.
Re: 1958 panel
Guitplayer #1426066 Wed Oct 06 2021 07:48 PM
Up on all fours. Complete Remodeling ....on back. I mean it has to be.
Tank cleaned and sealed. POR. Next is to pull out the engine. Have it rebuilt.
Remove the body from the frame.
Find someone to do the body work. Most the parts can be found. I guess the back
half along the bottom will have to be fabricated . I have on the way the 2 front fenders
and the 3 floor pans for the inside floor. Steps too. One pillar and a few other things.
I can handle the frame.
Its all original just needs some serious TLC.
Re: 1958 panel
Guitplayer #1427191 Mon Oct 18 2021 08:48 PM
Frame rolled out.
Re: 1958 panel
Guitplayer #1429176 Thu Nov 04 2021 03:15 PM
Engine at the doctor. I got the frame blasted. warming up in the garage for now. Then
I`ll start the brush on POR-15 coating. Finish with a spray POR top coat. Rear leaf springs
are out...shot. I`ll be able to paint underneath axle well.
Color of the trans and rear differential are blue.
Is it safe to assume the engine was the same color? There is no
way to tell now. Its at the rebuild shop and I'm sure it will come up what color to paint.
Blue or grey?
Re: 1958 panel
Guitplayer #1429279 Fri Nov 05 2021 01:53 PM
Few coats of POR . Turned out great. Panel is moving along.
At least when the engine is done , I can drop it back in.
Page 2 of 3 1 2 3
