The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
E V E N T Highlight
Southern
"STOVEBOLT"
Jamboree 2022
July 8 and 9
Lebanon TN
The Southern Bolters are planning their area get together in
conjunction with the
Southeast Truck Nationals at Cedars of Lebanon State Park (TN)
Check out the details, with new info on the Southern Bolters forum.
Plenty of other events in the Side Lot
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 67 guests, and 3 robots.
Forums59
Topics128,010
Posts1,036,482
Members45,915
Most Online1,229
Jan 21st, 2020
#1425383 Tue Sep 28 2021 05:06 PM
I'm nearly ready to paint my 1953 interior. I have replaced the inner cowl panels, so I now need to install a foot or two of the channel that the windlace slides into. I assume that I should drill a few holes in the center of the track and then weld it to the inner cowl panel. I'm a little concerned about grinding those welds flat enough to allow the new rubber to slide freely. I'll appreciate any advice regarding this. I also wondered if there is an adhesive that would work well enough that it wouldn't even need to be welded. I also wondered about possibly tack welding the new channel on the front edge, where it wouldn't show anyway. HELP
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
1950 Studebaker Starlight Coupe
Mike - like you described, I drilled 1/8" holes in the center of the track about 3" apart and plug welded it to the inner cowl panel. I then ground the weld so as to not interfere with the rubber installation. It worked out well for me. Just make sure to use a low heat setting on your welder so you don't blow through the track. They are not very thick. Good luck!!
Charlie
'51 3100 5-Window (Restomod in progress)
I did the same as Charlie when I replaced the lower portion of the tracks.
A small hole and a short blip with the MIG does the trick. You're doing it in the blind but sticking the cup centered on the track and pulling the trigger worked OK. I used a 3" cutoff disc to clean up the welds.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Moderated by  ndkid275
