The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Bob Kirk, Spicoli01, SavannahDog, Johnny N, MuddButtBaits, 55shaker), 165 guests, and 4 robots.
Forums60
Topics124,697
Posts1,006,493
Members45,007
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'61 Apache front shackle bolts
#1422868 Fri Sep 03 2021 09:25 PM
Does any of you know the differance in the '55-'59 set vs the '61? I have talked with 3 different companies and they can not tell me, nor do they have the '61 in stock. The front bolt with grease zert is all over, but the rear has a mount in the frame and the leaf. Both use a bolt with threads in the middle and the a tapper to more threads on the ends. The sleeve in the leaf and frame both have a coil for the threads? The pic for the '55-'59 look to be the same with the only thing different that I can see, is the two shackles have a square hole for a carriage bolt? I ordered a set and figured crossed the parts can me used or modified to work? I spoke to General Spring and asked if they could make a different bushing for the rear to accommodate the bolt from the front, he said yes. Is that what you guys would do if the parts coming will not fit? Why is this there not a conversion kit out there for these?
Re: '61 Apache front shackle bolts
MuddButtBaits #1422966 Sat Sep 04 2021 10:39 PM
Prior to '60 all 4x4s were NAPCO conversions, not factory built. Not much the same.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting (down!)
MuddButtBaits #1422991 Sun Sep 05 2021 12:40 PM
How hard is it to use the NAPCO shackles and modify the spring end and frame mount? Guess I will know next week lol.
MuddButtBaits #1423559 Fri Sep 10 2021 04:42 PM
One of the problems you are going to have with your shackles/bolts is that the 61-62 GM pickups had torsion bar suspension in lieu of the common 'A'-arm suspension that the '63 and later had. Your truck could be in the 'Donut hole' between the earlier NAPCO'S and later corporate 4x4's. Wm.
MuddButtBaits #1423619 Sat Sep 11 2021 04:05 AM
Ya, the parts were to small. Found a machine shop to fix rear shackles and then build new from scratch. See how it turns out?
Wm L #1423845 Mon Sep 13 2021 04:51 PM
"60 up were factory built 4X4, frames not the same between "C" & "K" .
BC
MuddButtBaits #1424318 Fri Sep 17 2021 11:49 AM
If anyone needs a set for the front on a pre 60, I have one. Cost $200 to have new ones made.
MuddButtBaits #1424322 Fri Sep 17 2021 12:04 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Selling parts outside the Swap Meet Forum is against Stovebolt guidelines.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
MuddButtBaits #1424452 Sat Sep 18 2021 11:20 AM
Muddbutt,
No selling on this page, but I would be interested to know the differences between the 2 sets you have. I struggle with 4x4 differences on some bits and pieces and to know what the differences are will make us all smarter.
Others might also be interested in your local source.
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
MuddButtBaits #1424635 Mon Sep 20 2021 01:39 AM
Sorry guys guy didn't mean to try to sell it. Hambone, it is hard to put pics on here. I can text you what I have and whet the difference is in them if you would like.
Moderated by  Hambone
