The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Bob Kirk, Spicoli01, SavannahDog, Johnny N, MuddButtBaits, 55shaker), 165 guests, and 4 robots.
Forums60
Topics124,697
Posts1,006,493
Members45,007
Most Online1,229
Jan 21st, 2020
Image Posting Policy
snap ring....how to measure
#1423310 Wed Sep 08 2021 02:55 PM
I hate to admit it but i guess I just never messed with many snap rings......but always managed to get what I wanted.
Nevertheless, my question is ..... how do you measure for snap rings. Do you ask for he OD of the shaft or do you ask for the OD of the groove the snap ring goes in???
I suspect Grigg will jump on this question?!
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Re: snap ring....how to measure
Achipmunk #1423320 Wed Sep 08 2021 04:29 PM
Internal or external snap rings? I've always had good luck using the OD of the shaft and relying on the snap ring to fill the groove. We used to use Tru-Arc internal snap rings for piston pin locks, bit after losing a couple at high speed, we switched to Spiro-Lock rings that don't respond to high piston speeds and come adrift.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Achipmunk #1423332 Wed Sep 08 2021 05:43 PM
Spriro-lock rings work great, but can be a pain to remove.
Remember to bring that question up this weekend and we can look the specs up in my machinist bible.
But, I think you go by the diameter of the bottom of the groove on OD rings and the ID of the groove on ID rings.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Achipmunk #1423346 Wed Sep 08 2021 07:12 PM
AD Addict
Here are two links that show the dimensions of standard internal and external snap rings.
Internal https://www.arconring.com/stamped-retaining-rings/internal/
External https://www.arconring.com/stamped-retaining-rings/external/
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Achipmunk #1423372 Thu Sep 09 2021 12:16 AM
As usual, when you dig into things you find there is a whole lot more than just "meets the eye". Thanks fellows.
I will say, before I went looking for them I used a set of dials and checked the OD of both the outside of shaft and then OD of the ring groove. As we sometimes say, heck, that's more than I needed to know!
Thanks again.
Moderated by  48bigtrucks, MNSmith
