Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
8 members (Flatblu4748, greenie-reddy, Gdads51, 1955firstseries, Bjstrudy, 1 invisible), 683 guests, and 6 robots.
The Zone
Forums65
Topics123,421
Posts999,183
Members47,264
Most Online1,229
Jan 21st, 2020
Page 1 of 3 1 2 3
#1421941 Thu Aug 26 2021 12:55 PM
Rmcea Offline OP
Can someone tell me what fluid is used on my 1950 gmc standard transmission
90 wt gear lube
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
“Grease Monkey” “Former herder of cats”
Farm Supply Store will have what you need.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
AD Addict
Tractor supply has Ford Tractor Transmission Oil, a 90 wt mineral oil which is the factory specs. Not all stores have it in stock and is hard to search for on their web site.
Here is a link: https://www.tractorsupply.com/tsc/p...90-transmission-fluid-2-gal?cm_vc=-10005
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Insomniac
I don't believe that there is a Tractor Supply Store in London Ontario or anywhere else in Canada.
Gord
1954 1/2 ton 235 4 speed
Phak1 suggestion is what I just used in my 52 chevy 1/2 ton. Non foaming, noncorrosive to yellow metals and not too slippery for synchronizers. It also quietened it down some.
1952 Chevy Pickup Truck
I use 75-90 synthetic.
What brand did you use and what is it's GL number?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod [stovebolt.com]
1956 8400 Wrecker w/Holmes 525 [stovebolt.com]
1956 9200 Tractor w/Allison Automatic [stovebolt.com]
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 CJ-5 Navy Jeep
Hughesville, MD
Rmcea Offline OP
Thank you
Try Canadian Tire. They're about the same as Tractor Supply.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Page 1 of 3 1 2 3
