The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (Cu29head, Gray_Ghost, 55shaker, 4 invisible), 125 guests, and 3 robots.
Forums60
Topics126,136
Posts1,019,641
Members45,442
Most Online1,229
Jan 21st, 2020
Image Posting Policy
brake bolt needed
#1420211 Wed Aug 11 2021 01:33 AM
37 GC Offline OP
I need the eccentric shoulder bolt with the crown nut that adjusts the e brake on the rear of my '37 1/2 ton. Can't find any listings on the usual sources online. I don't know the years of overlap but guessing all rear huck brakes were the same or similar. Anyone? PM me.
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Re: brake bolt needed
37 GC #1420289 Wed Aug 11 2021 09:13 PM
Group 5.158 Parking Brake Lever Anchor Bolt
1936-50 Car & 1/2 ton...(3/8-24 x 15/16) (w/eccentric)....475492
Mike B smile
Mike B #1420780 Mon Aug 16 2021 12:58 AM
37 GC Offline OP
thanks Mike. from a parts book? Know of a source?
Larry
37 GC #1421002 Wed Aug 18 2021 03:07 AM
Yes, Parts Book...I don't have a source, sorry!
Mike B smile
37 GC #1421003 Wed Aug 18 2021 03:45 AM
Do you have one to use as a pattern? It shouldn't be difficult to make one.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
37 GC #1421714 Tue Aug 24 2021 04:00 AM
9
37GC have u found your bolt?,if not im parting out a 52 gmc 1/2ton chassis and has complete rear axel come pull yer part 1-719-205-2203
Karl j Townsend
9% grade #1421718 Tue Aug 24 2021 04:44 AM
Your 52 would have Bendix brakes. Not compatible with Huck brakes on a '37.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
37 GC #1421720 Tue Aug 24 2021 04:51 AM
Why not just make an eccentric to thread onto a regular 3/8-24 bolt? All that takes is a 4-jaw chuck on a small lathe.
Kris Kristofferson
37 GC #1422149 Sat Aug 28 2021 01:39 PM
37 GC Offline OP
Yep, I know its a simple part to rig Jerry but no lathe at this household and moved away from old contacts.
Larry
klhansen #1422593 Wed Sep 01 2021 04:39 PM
9
Yes ur correct,but have several front brakes and dont see this adjuster ecentric on these huck brakes must be a rear brake only thing? as all seem to have the screw type adjuster at cap of wheel cyclinder?
Karl j Townsend
Moderated by  John Milliman
