We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,518
Posts1,032,212
Members45,797
Most Online1,229 Jan 21st, 2020
 brake bolt needed
OP
I need the eccentric shoulder bolt with the crown nut that adjusts the e brake on the rear of my '37 1/2 ton. Can't find any listings on the usual sources online. I don't know the years of overlap but guessing all rear huck brakes were the same or similar. Anyone? PM me.
Larry All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
 Re: brake bolt needed
Group 5.158 Parking Brake Lever Anchor Bolt 1936-50 Car & 1/2 ton...(3/8-24 x 15/16) (w/eccentric)....475492 Mike B
OP
thanks Mike. from a parts book? Know of a source?
Yes, Parts Book...I don't have a source, sorry! Mike B
Do you have one to use as a pattern? It shouldn't be difficult to make one. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
37GC have u found your bolt?,if not im parting out a 52 gmc 1/2ton chassis and has complete rear axel come pull yer part 1-719-205-2203
Karl j Townsend
37GC have u found your bolt?,if not im parting out a 52 gmc 1/2ton chassis and has complete rear axel come pull yer part 1-719-205-2203 Your 52 would have Bendix brakes. Not compatible with Huck brakes on a '37.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
Why not just make an eccentric to thread onto a regular 3/8-24 bolt? All that takes is a 4-jaw chuck on a small lathe. Jerry
OP
Yep, I know its a simple part to rig Jerry but no lathe at this household and moved away from old contacts.
Yes ur correct,but have several front brakes and dont see this adjuster ecentric on these huck brakes must be a rear brake only thing? as all seem to have the screw type adjuster at cap of wheel cyclinder?
Karl j Townsend
