First splashes of paint made it onto a couple of parts... which means the grill shell can go back together once some of the more visible pieces are color sanded. Due to the fact that it's a low buck project... i painted the grill rather than spend $1000 cdn to have it redone. In the end the black actually goes with my over all style that I have in mind for the truck.
Hot rodded 40 pickup.... in the dark of night she’s a looker.
Started ripping into the crusty rear that I picked up for the truck. To be clear, I live in a location that doesn't have a lot of access to old parts and shipping can/usually does cost more than the part. So while it's not ideal for a couple of reasons; I ended up grabbing an 8.2 rear for the truck out of a 71 lemans. Being from a Lemans it was a coil over car so lots of grinding on bracketry that is no longer required
Have a few parts on the way to hopefully help it out: Moser engineering diff cover Summit Racing Axles Richmond gears 3.73 R/P Yukon Dura Grip and a Richmond Complete Ring and Pinion Installation Kit
Also snagged new and complete drum brakes from craigslist
Got some degreasing done after cutting off the brackets and melting out the old bushings. Then threw some por15 at the rear and eventually dropped it off at the local 4x4 shop to have teh r/p and diff setup
Changed up the look of the engine to better suit my style, which is heading towards early to mid 60's hot rod... blacked out the intake/heads and ditched the modern valve covers for some basic chrome.
Rear shocks were mounted to an awkwardly mounted plate, outside of the ugly welds the plate didn't line up well with the frame; causing the shock body to rub the frame. I took the cutting wheel/grinder to it and will be running a bar across the frame to mount new shocks
Based on the condition of the frame, I've decided to leave the body on the frame and not do a complete frame off. Mostly b/c I'm lazy and the body sits nicely as it is. Got the rear frame section cleaned up and threw some por-15 at it. Followed that up by coating it with some ghetto tremclad ...Good enough for a farm truck
Began working on the front of the truck...got the frame and the leaf springs cleaned up, took the springs apart and removed a leaf from each side. Dropped the beam and painted it while I was at it and the front rims got some paint love.
