We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
If you can't find an original one, they're available from the usual suspects. According to the FAM, they're the same for 1/2 ton and up. Link [store.fillingstation.com]
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
John, The correct part number for the right side is 3693788 and for the left is 3693787. They are specific to the one ton as the leaf springs are wider than the 1/2 and 3/4 ton. The Filling Station is wrong, those part numbers they show are 1/2 and 3/4t part numbers (3693687 and 3693688). I will check my parts as I may have a spare set, I will let you know.
Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant)
My mistake. I misread the FAM. 3100-3600 are the same, but like Dave said, the 3800 uses different mounts.
