The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy Birthday U S A !
Celebrating
Life, Liberty
and the
Persuit of Happiness
Happy Birthday
A M E R I C A
July 4 - 246 years
Stories, Pictures, Thoughts
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (3B, 3800GUY, coilover, 3 invisible), 102 guests, and 3 robots.
Forums59
Topics128,081
Posts1,037,108
Members45,928
Most Online1,229
Jan 21st, 2020
#1419130 Mon Aug 02 2021 12:54 PM
53again Offline OP
Hello all,
Are the rivets holding drums to hub on front of 53 3100 nessary ? if so where can i find replacements ? I need to change out to new drums seems like it would be easy and faster to service brakes if i didnt need to pull hub. Thanks Aaron
It's not really necessary to replace the rivets. The hub will center the drum just like the rears. Just grind off the heads and punch them out.
Fred
53again Offline OP
Thanks Fred, kinda what i was thinking, just wanted to get input from others, Aaron
If you want to attach the drums to the hubs to keep them from slipping off during a tire change, just tap the rivet holes with a thread, and use a flathead machine screw countersunk even with the surface of the drum to hold it on. Some rear drums are attached to the hubs that way.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
53again Offline OP
Sounds like a good idea, thanks Jerry
AD Addict
If you do it this way, make sure you use anti-seize compound on the threads. The brake drums see the harshest environment which will rust those screws in solid. I would also use a higher grade torx head so it would have some beef when trying to remove them. You may want to use stainless.
Whatever you do, don’t use a slotted flathead machine screw. That will decrease you chance of removal.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Here's a chart, you might be able to find actual rivets on Ebay.
When using a rivet you can peen them.
[img]https://www.stovebolt.com/ubbthread...er/33756/filename/brake-rivets-chart.jpg[/img]
Working around the hub when trying to do a front brake job is going to be incredibly frustrating. The wheel bearings are going to need to be repacked periodically, so doing that in conjunction with a brake job (which requires removing the hubs) makes sense to me. Since the current drums have been on there close to 70 years, how often do you plan on having to change them? Chances are the screws won't have to be removed again in your lifetime!
Kris Kristofferson
AD Addict
Jerry, as always, you make a very good point. Still, it would’t hurt to add a little anti-seeze, just in case!
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Moderated by  Justhorsenround
