The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (68ironhead, Alainfrenchie54, Achipmunk, 32vsnake, Bolter Finally, DennisM, 2 invisible), 122 guests, and 3 robots.
Forums60
Topics124,614
Posts1,005,764
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
1962 GMC dually front axle swap?
#1419397 Wed Aug 04 2021 02:24 PM
GMC-V6 Offline OP
So can you replace the torsion bar A frame front suspension and such over to a bit more modern coil spring frame type front end? On a DRW truck??
It's a 6 tire 2 axle truck😁I want it to stay that way😍
Mike
Re: 1962 GMC dually front axle swap?
GMC-V6 #1419505 Thu Aug 05 2021 02:20 PM
3B Offline
Hy GMC-V6, welcome, I am sure a swap to a coil spring type crossmember from a newer truck could be accomplished, if you went new enough you could even end up with disc brakes. That being said, why do you want to change from a rare and unique suspension system that provides a very comfortable ride?
GMC-V6 #1419509 Thu Aug 05 2021 03:38 PM
GMC-V6 Offline OP
Because they make wheel bearings for the 72-87 trucks they don't make wheel bearings for my truck anymore. Plus disc brakes and possible power steering aren't a bad thing either😉
GMC-V6 #1419516 Thu Aug 05 2021 04:47 PM
Mike
Not sure about "more modern", most K series G.M. pickups have used torsion bar front suspension since 1987.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting (down!)
GMC-V6 #1419532 Thu Aug 05 2021 07:37 PM
"Front axle swap"?????????? I don't think I've ever seen a vehicle with a front axle with torsion bar suspension! Maybe an early Volkswagen bug?
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
GMC-V6 #1419534 Thu Aug 05 2021 08:31 PM
3B Offline
Hy GMC-V6, I just checked RockAuto's website and SKF bearings are still available BR2 and BR5 and they are less than $8.00 each.
GMC-V6 #1419590 Fri Aug 06 2021 12:07 PM
GMC-V6 Offline OP
I need bearings B48 and B47 two of each one.
3B #1419591 Fri Aug 06 2021 12:19 PM
GMC-V6 Offline OP
🤔?BR2 BR5? 🧐You must not be looking at the right truck at all.
My front wheel bearings are B47 and B48😉
GMC-V6 #1419592 Fri Aug 06 2021 12:22 PM
GMC-V6 Offline OP
My truck isn't a 4 wheel drive it's a Rear wheel drive so it's a C-Series...
3B #1419593 Fri Aug 06 2021 12:26 PM
GMC-V6 Offline OP
My truck takes B47 and B48 wheel bearings.
Page 1 of 3 1 2 3
Moderated by  Hambone
