The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (D B Cooper, 29tons, 55_2nd_Series, EdPruss, baldeagle, 1 invisible), 113 guests, and 3 robots.
Forums60
Topics124,607
Posts1,005,710
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
4 Piece Hood-Disassembly
#1419017 Sun Aug 01 2021 03:51 PM
I'd like to separate the 2 pieces of each hood half. I plan on sandblasting the larger section and molasses soak the smaller section. Any suggestion on how to remove the hinge pin holding them together?
1946 1/2 ton restomod
Re: 4 Piece Hood-Disassembly
Trikebent #1419025 Sun Aug 01 2021 04:32 PM
I have to assume you're talking about a hood that's hinged in the middle (pre-47). It helps it you create a signature that includes info on the truck you're working on. Or at least tell us with each post.
I removed the hinge pin on a Model A years ago just by driving it out with an other rod that was a bit smaller. You definitely have to be sure the hood halves aren't rusted to the pin.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Trikebent #1419033 Sun Aug 01 2021 04:59 PM
Thanks for the signature suggestion.
Yes, pre '47, center hinge hood.
Trikebent #1419050 Sun Aug 01 2021 07:05 PM
Thanks for the tip on the signature.
Hood is for 1946, split in the center.
Trikebent #1419079 Sun Aug 01 2021 10:24 PM
I just drove them out on my '40. Replaced them with brass rod.
Dennis
40 Chevy 1/2 ton
Trikebent #1419144 Mon Aug 02 2021 04:36 PM
The guys suggestions are the same process I used on my ‘46. I used a blunt 6 penny nail as a punch. Once one end is driven out far enough a pair of pliers can be used to pull the remaining rod from the hinge “chamber”.
Trikebent #1420296 Wed Aug 11 2021 10:55 PM
you will have to work them carefully to get them out or if they are really bad i have had to carefully bend the hinge loops to get them apart. i have found that putting them back together is easy if you get one end started, use a punch on the other end to line it up then use a drill on slow speed to spin it and it will go right in and smoothly. i use a bit of lithum grease on the rod.
Moderated by  HandyAndy, klhansen
