The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
7 members (Justhorsenround, DaveV, Marty_in_Mesa, Darling, carbking, Jefe 56), 159 guests, and 3 robots.
Forums60
Topics127,724
Posts1,046,959
Members46,403
Most Online1,229
Jan 21st, 2020
Page 1 of 3 1 2 3
#1418664 Thu Jul 29 2021 07:17 PM
TUTS 59 Offline OP
Crusty Old Sarge
I know this may be a bit of topic for the forum but we all have some place we do the work on our trucks. With my 2 post lift now becoming a reality I need to figure the layout for my shop space. Like many of you I don't have that much to work with and always need more, the budget is forever another factor. I'm working with a 28' x 28' foot print so I want to optimize the area I have.
I would like to see some of the layout that all of you are working with, nothing fancy just a basic drawing. With any luck I can use some of your ideas and make the most out of the room I have. Thanks.
Craig
Come, Bleed or Blister something has got to give!!!
TUTS 59 #1418700 Fri Jul 30 2021 12:16 AM
FWIW i recently visited a retired fella to pick up some rear fenders. He was working on a 41 Chevy truck in a 24x28 or 24x26 building he built. He had a center overhead I-Beam he used to hoist and lift with a chain fall. But my impression was - that was a very efficient home set up and one I would be proud to work in. Plenty of room to work on a vehicle; had upper cabinets, and a bench-. He had everything he needed within arms reach and room to walk around the vehicle and work. One third was loft - two thirds open ceiling - clear span no center post.
TUTS 59 #1418703 Fri Jul 30 2021 12:43 AM
You reminded me that I wanted to start a new thread a few days ago. Maybe folks will participate and post pictures of their shops. Maybe that will help you with your design quest. See the "Show us your shop! Where you work on your Stovebolt!!" topic.
TUTS 59 #1418707 Fri Jul 30 2021 01:21 AM
back yard wrench turner
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
TUTS 59 #1418768 Fri Jul 30 2021 04:58 PM
Check out Lugnutz (Jay's) shop...he did a build series here. He packs a lot into a 24x24 garage maximizing every available square inch! Worth a look...
Mike B smile
TUTS 59 #1418772 Fri Jul 30 2021 05:38 PM
TUTS 59 Offline OP
Crusty Old Sarge
Mike, I saw Lugnutz series he did, I told him I was going to steal his overhead shelf design. He has a lot going on in a small space.
Craig
TUTS 59 #1418780 Fri Jul 30 2021 06:49 PM
Think of it as a "cell" like many companies use in manufacturing. Basically its to set up your shop to use the least amount of walking......to get to the tools you use the most often.
.....when putting stuff in my shop and making something like a "cell" I did end up moving some things around to make it more user friendly. I bet most of us have did these. The only thing "in concrete" to begin with should be the Lift.
FWIW.....I ended up moving my air compressor, my bead blasting cabinet and moved the wood working stuff about three times.
GO FOR IT CRAIG, you'll get it figured out.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
1952 Chevy Panel [photos.app.goo.gl]
[photos.google.com]
Mike B #1418788 Fri Jul 30 2021 08:00 PM
Mike B smile
Any chance you have the link?
TUTS 59 #1418792 Fri Jul 30 2021 08:36 PM
TUTS 59 Offline OP
Crusty Old Sarge
Craig
NorCal52Suburban #1418830 Sat Jul 31 2021 01:54 AM
If I remember correctly Lugnutz did a few posts on the different phases of the build. Maybe he will jump in with a link.
Mike B smile
Page 1 of 3 1 2 3
