The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (cmayna, Jon G, coilover, Green235, 5 Window 9434, carbking, 1 invisible), 162 guests, and 4 robots.
Forums60
Topics125,015
Posts1,008,932
Members45,121
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Gas fill tube
#1418662 Thu Jul 29 2021 06:55 PM
Age must be getting to me. 1954 - 3100. I have out these huge rubber grommets on several times in the past. I guess I keep secrets pretty good. I can't remember the easier way to put them on, tried olive oil, 30 weight, grease and a slab of bacon. My hands are very strong and the grommet is new, maybe I should try J&Y jelly. What is the method or secrete? Doc.
Re: Gas fill tube
Doc.Hall #1418713 Fri Jul 30 2021 02:14 AM
Is the tank in place? That would make it all but impossible, so I am guessing that is not the case.
Re: Gas fill tube
Doc.Hall #1418717 Fri Jul 30 2021 02:48 AM
Insomniac
I managed to work it in. Used a large drift punch to push it in - a screwdriver would be too sharp and would slice through it. Had to go around and around pushing a bit at a time until it was done. Took a while!
Gord
1954 1/2 ton 235 4 speed
Re: Gas fill tube
Doc.Hall #1418720 Fri Jul 30 2021 04:26 AM
Fox Offline
Mine were a bugger to get on with the tank in cab.
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- Rusty- the puzzle box lid for the C10.
1950 Chevrolet 1300- in progress to shiny.
1962 AMC Rambler American- my wife’s
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Gas fill tube
Doc.Hall #1418730 Fri Jul 30 2021 11:09 AM
I used Vaseline on it. Second time I had to do this because the first one I installed "cracked" after 2 years so the replacement was from Steele Rubber Products. The gas tank was installed but the filler neck was not.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: Gas fill tube
Doc.Hall #1418834 Sat Jul 31 2021 02:18 AM
Have you tried soap? I remember putting a driveshaft carrier bearing in. Instructions said to use soap as a lube. First tried dish soap(detergent), didn't work at all. Engine oil didn't work. Worked up a thick lather from a bar of bath soap and it went in easily.
Harold Wilson
41 Chevy 3/4 Ton
Moderated by  HandyAndy, klhansen
