The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (buoymaker, 53 green 1- ton, aircommando462, Hotrod Lincoln, 2 invisible), 121 guests, and 3 robots.
Forums60
Topics124,655
Posts1,006,159
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 715 of 720 1 2 713 714 715 716 717 719 720
Re: What did you get done on your bolt today????
BIG CHEVY 3600 #1418270 Tue Jul 27 2021 12:24 AM
Today I finished prepping all the sheet metal w my mixture for the surface rust. Sprayed undercoating inside both doors; white lithium on window tracks and other moving parts; drained radiator because it had that old brown water smell in it. Once I removed bottom hose antifreeze Did come out. I’m guessing it May have been low and the seller perhaps topped it w water. Either way, I didn’t bother flushing system but just drained the dirty stuff out and put in new. Checked antifreeze later in the day and it was still up top And nice and green.
Tomorrow my mail comes.....rubber sleeve for floor hand brake and floor shifter, boot for floor starter, metal cover for master cylinder instead of the cheap stripped plastic one, then the rubber cover for floor above master cylinder, couple of rubber door stops.
Still need to purchase the seal for around the hood vent as water(rain) gets in there and floods the inside floor. Once this and windshield seal are taken care of I’ll POR15 the inside floor and put back the padded floor along w the one pice rubber floor mat.
This is for my 52 1 ton.
sambo42xa-Southern NH
“all my responses are My own opinions and/or suggestions. I do not claim to know all there is to know, but I May have dealt with it before and offering my knowledge”
I can also be a smart ****, but it’s all good, so don’t take offense.
BIG CHEVY 3600 #1418448 Wed Jul 28 2021 02:45 AM
Got some final pit filling done on the inner grille bars and got them final painted today. Used a rattle can of Rustoleum Canvas White which I found was a pretty decent match for Waldorf White.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
BIG CHEVY 3600 #1418606 Thu Jul 29 2021 12:01 PM
Crusty Old Sarge
I finally got a chance to bolt up the new clutch and pressure plate on my 327, I still need to mount the hydraulic throughout bearing.
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
BIG CHEVY 3600 #1418798 Fri Jul 30 2021 09:16 PM
Got the original interior paint matched up on the 54-3100. Cost a fortune in small 1/2 pint cans but it looks good. No runs, no dips and a homerun. More work this coming week. Doc
BIG CHEVY 3600 #1418852 Sat Jul 31 2021 05:38 AM
Reconfigured my rotisserie back into an engine stand and got the engine mounted on it. I extended the length of the engine stand a bit from the way it came, used the rear rollers at 30 inches width on the front and the extended casters on the rotating end (38 inches wide). Looks pretty stable. These stovebolt sixes are pretty long and I didn't want to use one of those cheesy 3 wheel stands, opting for a cheesy 4 wheel stand that I modified.
BIG CHEVY 3600 #1418908 Sat Jul 31 2021 08:17 PM
Looks great Kevin!
-David
1953 2-Ton GMC
BIG CHEVY 3600 #1418913 Sat Jul 31 2021 08:51 PM
I picked the new motor up yesterday and have been putting all the parts and pieces on it. With any luck I’ll have it in the truck by the end of August.
Scat forged 3.75” crank
6” Forged H-beam rods
Forged DSS -21 dish pistons
9.1:1 compression ratio
Aluminum heads ported 205cc
4-bolt main
AFR main and head studs
Tri-coated race bearings
TFS stage 1 cam
450hp/465tq
Blower ready
1959 Apache 3200 stepside
SBC 350
Rebuilt M20 Transmission
Rebuilt GM 12 Bolt rear end
18" Detroit Steel D-Town Wheels
BIG CHEVY 3600 #1418943 Sun Aug 01 2021 01:40 AM
Getting into the 'Rusto-Mods' bed resurrection. New rear support.
Covered in rust dust and metal filings, but better that any day at work.
One more day left in the weekend. yahoo
'Rusto-Mod'
'52 Chevy 3600 truck
C4 Corvette front/rear suspension & drivetrain
Everything else looks old and stock
Trucks, Trucks.....and more Trucks
Praetor #1418949 Sun Aug 01 2021 02:39 AM
Praetor,
WOW. Very impressive. Running a stronger than stock frame???, 'cause THAT looks like it will make pretzels out of a factory one.
'Rusto-Mod'
Chip O #1418997 Sun Aug 01 2021 02:10 PM
Originally Posted by Chip O
Praetor,
Hi Chip O,
Good point! I planned on Boxing the frame and beefing up the crossmembers when I add boost. I’m running street tires with minimal traction currently but should I box it now with 450hp/465tq?
SBC 350
Moderated by  Justhorsenround
