The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Bruce36 1.5, Jerry M., Justhorsenround, fixite7, J Lucas, DaveV), 80 guests, and 3 robots.
Forums59
Topics128,613
Posts1,041,924
Members46,061
Most Online1,229
Jan 21st, 2020
NJC Offline OP
Stovebolters, Fellow I met at my hardware store was cleaning out his garage and gave me a distributer. He said it would work in either 216 or 235 motors. Does the vacuum Advance line get hooked up to the trico wiper motor? V/r, Nick
1952 Chevrolet Suburban
More pictures in Photobucket
1948 Chevrolet 3100 1/2-Ton
Curmudgeon
No.
The path is from diaphragm connection on the side of the distributor to a small metal tube that travels up to the carburetor fitting (port above the throttle plate). Do you need a picture? The distributor may be pre 1954. The part number on the breaker plate can be used to determine application.
There are a few differences in the 216 and 235 distributors, mainly in the centrifugal advance numbers, and also the height of the caps and rotors used on early and late model distributors. When the electrical systems went to 12 volts, a taller cap and rotor and a slightly different height center shaft was installed to minimize the tendency for the high voltage to flash over to the breaker plate if a plug wire came loose. As long as the cap, rotor, and distributor match up, the complete assembly can be installed and will work in either engine. There's also a difference in the drive gear that is used with steel or cast iron camshafts.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
NJC Offline OP
Buoymaker: No on pics at the moment cause not ready to place on my 235.Thanks on the offer. Hotrod: Going to cleanup the distributer better & plan to show it to you, et.al., at a meet & greet sometime. Thanks for the clarification guys! V/r, Nick
I've got a little bit of reference material on some of those distributors by the part number on the breaker plate. Another difference I forgot to mention was a change in point gap and possibly the cam lobe profile in the mid 1950's which changed the "dwell" setting.
Kris Kristofferson
Ernest Hemingway
NJC Offline OP
Sir, I'll get better pics & send them along so we know what exactly we're dealing with. Thanks Hotrod. V/r, Nick
Moderated by  Rusty Rod
