Oh Lord, I just gotta find it....
Forums59
Topics127,986
Posts1,036,241
Members45,906
Most Online1,229 Jan 21st, 2020
All the old trucks have rear fenders and tires that don't line up. No one knows why GM did this, but 99% have the tires to far forward. The fix is to drill a new locating hole in the axle mounts and slide the drivetrain backwards an inch or little more. Your fenders are likely original or at least mounted in the original holes.
JoeR, I agree with Rich’sToys to leave the steel if it’s a daily driver, but wood sure is pretty. My ‘57 3200 has steel from previous owner so I purchased a 1/2” rubber mat to quite it down and protect the paint if I ever get that done.
1957 Chevy 3200 PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
OP
JoeR, With all due respect, unless you're a stickler for originality, I would leave the steel bottom in the bed. Obviously it was put there because the original wood was shot. Why undo something that was definitely an improvement? Just my thoughts--it's your truck, not mine. Hi Rich, The steel bed wasn't put in very well, there are gaps and it just look ugly to me. It's all got to come out to replace some other parts so my plan was to go with the entire bed kit from Mar K. My thought was that since I'd be buying everything, the bed, tailgate, wood and mounting hardware from one source it would fit together better rather than trying to find the parts I need from separate manufacturers. Right now I'm putting together a list of things that the truck needs and what all the costs will be. I'm still trying to decide if I want to go with just making it a driver, restoration or doing a full engine swap. A lot is going to depend on finances. As always. Joe
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Just a side note about Mar-K. The former owner is an active member here, 59fleet, and has been really good about answering bed related questions. Even though the company changed owners a few years ago they still strive to put out a good quality product and their customer service is great.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
Re. the steel bed, I believe GMCs used a steel bed NO? And good luck at DMV, I try to deal with AAA they can handle some transfer/registration issues, few DMV employees are up to speed with old vehicles.
Hi Rich,
Joe That makes sense. You know your own situation, and I don't. Sounds like you have a good plan. Keep us posted.
Not sure why anyone would shorten a short bed but I guess, as they say, to each his (or her) own. Any thoughts on the 12 bolt, 3.73, 6 lug rear end for this truck? I've also found an online place that has Artillery wheels but I'm thinking they may have to wait until I get the basics done first. I can throw a pair of steel wheels on there for now. Joe Seems to be common with Hot Rodders, they will often swap the chassis with a car chassis. The trucks I've seen the beds shortened on (yes, 1/2 tons) had pretty souped up engines. Here's an example of such a '46. https://www.youtube.com/watch?v=ta3CJ5dAs7QI'm looking for a simpler life, my 235 is all I need, I just need the driveline spiced up a bit. My truck is painted with Rustoleum, best I can tell...with a brush.
