The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
E V E N T Highlight
Southern
"STOVEBOLT"
Jamboree 2022
July 8 and 9
Lebanon TN
The Southern Bolters are planning their area get together in
conjunction with the
Southeast Truck Nationals at Cedars of Lebanon State Park (TN)
Check out the details, with new info on the Southern Bolters forum.
Plenty of other events in the Side Lot
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (bowtietim, Hotrod Lincoln, hippydave, Rsqwhite, 1 invisible), 71 guests, and 3 robots.
Forums59
Topics127,967
Posts1,036,049
Members45,902
Most Online1,229
Jan 21st, 2020
Image Posting Policy
#1417661 Wed Jul 21 2021 10:18 PM
Today I noticed that the Classic Industries catalog shows a large sheet metal panel that they show installed directly beneath the radiator support frame, for 47 thru 54 pickup trucks. I know that my 53 half ton did not have one in it when I bought it. I looked in the FAM manual and I could not find any reference to it. I looked in the Jim Carter's catalog, and found NO reference to it there either. Classic Industries calls it a "radiator support". I would call it a splash guard. I guess my question is: did this part actually exist in the original 3100 AD trucks? Their picture makes it look like it sandwiched between the crossmember and the radiator support. It appears to span from one frame rail to the other, and extends in front of and behind the radiator. Please advise.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
1950 Studebaker Starlight Coupe
Sir Searchalot
Give us the Classic part number. 61-712 ? Yes, correct for 53. Should be called "Grille Support". 47-53........... NOT 47-54. That one is GMC ONLY. 61-712G
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
"We have no time for comment, every man will make his own. LET IT BE MADE WITH POWDER AND BALL!!!"
I recommend invoking MIL-T-FP41c when machining and fabricating
I used to think beer was bad for me, so I gave up thinking.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
You need one. It forces air through the radiator. I call it a lower baffle.
Here's that part from Classic Industries Link [classicindustries.com]. I believe other vendors carry them also. (LMC PN 38-8940 - they call it a Grill Support Panel)
They say fitment is 47-53. The FAM shows only 54 front sheet metal, which is probably why you couldn't find it.
The bottom of your grille bolts to it, and like the other guys said, you need one. You might be able to get an original from one of the members. Try posting in the Swap Meet.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Thanks for all the help. You guys are the best.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
Moderated by  Justhorsenround
