The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (Hotrod Lincoln, Drew54, fixite7, D B Cooper, Jethro in Va, Hanks custodian, 1 invisible), 136 guests, and 4 robots.
Forums60
Topics129,216
Posts1,047,936
Members46,222
Most Online1,229
Jan 21st, 2020
#1417661 Wed Jul 21 2021 10:18 PM
Today I noticed that the Classic Industries catalog shows a large sheet metal panel that they show installed directly beneath the radiator support frame, for 47 thru 54 pickup trucks. I know that my 53 half ton did not have one in it when I bought it. I looked in the FAM manual and I could not find any reference to it. I looked in the Jim Carter's catalog, and found NO reference to it there either. Classic Industries calls it a "radiator support". I would call it a splash guard. I guess my question is: did this part actually exist in the original 3100 AD trucks? Their picture makes it look like it sandwiched between the crossmember and the radiator support. It appears to span from one frame rail to the other, and extends in front of and behind the radiator. Please advise.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
1950 Studebaker Starlight Coupe
Sir Searchalot
Give us the Classic part number. 61-712 ? Yes, correct for 53. Should be called "Grille Support". 47-53........... NOT 47-54. That one is GMC ONLY. 61-712G
You need one. It forces air through the radiator. I call it a lower baffle.
Here's that part from Classic Industries Link [classicindustries.com]. I believe other vendors carry them also. (LMC PN 38-8940 - they call it a Grill Support Panel)
They say fitment is 47-53. The FAM shows only 54 front sheet metal, which is probably why you couldn't find it.
The bottom of your grille bolts to it, and like the other guys said, you need one. You might be able to get an original from one of the members. Try posting in the Swap Meet.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Thanks for all the help. You guys are the best.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
Moderated by  Justhorsenround
