We are still asking: What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Looking for info about changing the pinion seal 57 1 ton 3 spd heavy duty. Can I remove just the 5 bolts in part# 4 and parts 1,2,3 come off together or do need to remove parts# 1,2,3 and then 4 to get to the seal in part #4 See pic from manual
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
I believe its a 1-5/8 socket and you can use a pipe wrench on yoke wedge on ground to hold it. Its going to take a lot of grunt to break the nut loose. Possibly need a long persuader on ratchet
You "may" need to take the socket to a grinder and thin the walls a bit to get it to fit. Then with the full weight of the truck on the rear tires, use a 3/4" breaker and 3' cheater pipe. Or a Good impact. If working on a lift I use a crude wrench I made years ago to slip over the yoke that locks up on the frame or spring. Good info here.
Good Luck,
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1951 Farmall Super A
You'd have to block the tires somehow unless you use a wrench that holds the yoke. If the yoke is free to turn, the truck will just move. It could even roll over chocks if you're reefing on the wrench hard enough. A piece of bar stock with a couple holes drilled to match bolts going into the yoke where the u-joints connect should do the trick. I have one that has a hole in the center for the socket and 4 holes to bolt to the yoke.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
Job is done per your recommendations, but only after I hired a mechanic to do the job. He used RTV sealant between #4 part and diff carrier which leaked and he need to two pinion seals because he refused to remove the entire original seal before trying to cram the new seal in place. So I paid him 193 bucks and still had to take it apart this afternoon and fix it myself. I was going to let him fix it when he gets back from vacation as he left town the next morning after getting my cash.But once bitten twice shy and the more I thought about the more I remembered if you want a job done we’ll do it yourself. 309 bucks and three hour of my labor and I did it it’s completed and not leaking and I got a new socket tool set from HF yea me! Why is good help so hard to find?
