The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (DavidBraley, Goach2, dunfire, 3 invisible), 111 guests, and 3 robots.
Forums60
Topics127,506
Posts1,032,019
Members45,793
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Pinion seal
#1417659 Wed Jul 21 2021 10:15 PM
Duwop Offline OP
Looking for info about changing the pinion seal 57 1 ton 3 spd heavy duty. Can I remove just the 5 bolts in part# 4 and parts 1,2,3 come off together or do need to remove parts# 1,2,3 and then 4 to get to the seal in part #4 See pic from manual
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800
In the Stovebolt Gallery [stovebolt.com]
More pix on Flickr [flickr.com]
Re: Pinion seal
Duwop #1417666 Wed Jul 21 2021 11:12 PM
You must remove the nut then washer then yoke. Then you can take off the 5 bolts and get to your seal. John
1949 gmc 1-ton
Re: Pinion seal
Duwop #1417668 Wed Jul 21 2021 11:23 PM
Duwop Offline OP
Thanks John, yeah I went back looking at manual and finally figured it out. Is there an easy way or special socket to use to get that big not off.
1957 Chevy 3800
Re: Pinion seal
Duwop #1417669 Wed Jul 21 2021 11:31 PM
I believe its a 1-5/8 socket and you can use a pipe wrench on yoke wedge on ground to hold it. Its going to take a lot of grunt to break the nut loose. Possibly need a long persuader on ratchet
1949 gmc 1-ton
Re: Pinion seal
Duwop #1417670 Wed Jul 21 2021 11:34 PM
I have gotten them off with an air impact
1949 gmc 1-ton
Re: Pinion seal
Duwop #1417675 Thu Jul 22 2021 12:06 AM
You "may" need to take the socket to a grinder and thin the walls a bit to get it to fit. Then with the full weight of the truck on the rear tires, use a 3/4" breaker and 3' cheater pipe. Or a Good impact. If working on a lift I use a crude wrench I made years ago to slip over the yoke that locks up on the frame or spring. Good info here.
Good Luck,
RonR
1970 340 Duster
1951 Farmall Super A
Re: Pinion seal
Duwop #1417677 Thu Jul 22 2021 12:12 AM
You'd have to block the tires somehow unless you use a wrench that holds the yoke. If the yoke is free to turn, the truck will just move. It could even roll over chocks if you're reefing on the wrench hard enough. A piece of bar stock with a couple holes drilled to match bolts going into the yoke where the u-joints connect should do the trick. I have one that has a hole in the center for the socket and 4 holes to bolt to the yoke.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Re: Pinion seal
Duwop #1417681 Thu Jul 22 2021 12:22 AM
Duwop Offline OP
All of these suggestions so great, so thanks to all. I’ll give it a go tomorrow and see if it work out.
1957 Chevy 3800
Re: Pinion seal
Duwop #1417695 Thu Jul 22 2021 02:20 AM
I have a 4’ pipe wrench I use for that, works great.
Ed
Re: Pinion seal
Duwop #1418712 Fri Jul 30 2021 01:55 AM
Duwop Offline OP
Job is done per your recommendations, but only after I hired a mechanic to do the job. He used RTV sealant between #4 part and diff carrier which leaked and he need to two pinion seals because he refused to remove the entire original seal before trying to cram the new seal in place. So I paid him 193 bucks and still had to take it apart this afternoon and fix it myself. I was going to let him fix it when he gets back from vacation as he left town the next morning after getting my cash.But once bitten twice shy and the more I thought about the more I remembered if you want a job done we’ll do it yourself. 309 bucks and three hour of my labor and I did it it’s completed and not leaking and I got a new socket tool set from HF yea me!
Why is good help so hard to find?
1957 Chevy 3800
Page 1 of 2 1 2
Moderated by  Grigg
