Oh Lord, I just gotta find it....
Forums59
Topics127,967
Posts1,036,036
Members45,902
Most Online1,229 Jan 21st, 2020
OP
Today I noticed that the Classic Industries catalog shows a large sheet metal panel that they show installed directly beneath the radiator support frame, for 47 thru 54 pickup trucks. I know that my 53 half ton did not have one in it when I bought it. I looked in the FAM manual and I could not find any reference to it. I looked in the Jim Carter's catalog, and found NO reference to it there either. Classic Industries calls it a "radiator support". I would call it a splash guard. I guess my question is: did this part actually exist in the original 3100 AD trucks? Their picture makes it look like it sandwiched between the crossmember and the radiator support. It appears to span from one frame rail to the other, and extends in front of and behind the radiator. Please advise.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1953 Ford Victoria 1950 Studebaker Starlight Coupe
Sir Searchalot
Give us the Classic part number. 61-712 ? Yes, correct for 53. Should be called "Grille Support". 47-53........... NOT 47-54. That one is GMC ONLY. 61-712G
Watch out for careful drivers!!! I'm away on an ego trip. Will be back on Feb 30. I'm not an Auto Mechanic, but I play one on TV. I charge $0.02 for every opinion and I take Paypal. Plan B is always better than plan A, by definition. "We have no time for comment, every man will make his own. LET IT BE MADE WITH POWDER AND BALL!!!" I recommend invoking MIL-T-FP41c when machining and fabricating I used to think beer was bad for me, so I gave up thinking. Sometimes no nonsense makes sense, in a sense. You can't teach a new dog old tricks. Honk if you're Amish
You need one. It forces air through the radiator. I call it a lower baffle.
Here's that part from Classic Industries Link [ classicindustries.com]. I believe other vendors carry them also. (LMC PN 38-8940 - they call it a Grill Support Panel) They say fitment is 47-53. The FAM shows only 54 front sheet metal, which is probably why you couldn't find it. The bottom of your grille bolts to it, and like the other guys said, you need one. You might be able to get an original from one of the members. Try posting in the Swap Meet.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
OP
Thanks for all the help. You guys are the best.
