The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Keep your restoration going
Keeping your resto going
A good bit of advice nestled in the FAQ page.
Don't
Irwin Arnstein working on his
1959 Chevy 1-Ton
Read the article.
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Justhorsenround, Harold41, Atticusnine, Hotrod Lincoln, carryall jerry, Jimmie D), 111 guests, and 4 robots.
Forums59
Topics128,524
Posts1,041,185
Members46,036
Most Online1,229
Jan 21st, 2020
Here is a pic of the distance from my exhaust pipe and brake res. mounted to
frame.
Is this too close and should I put up a heat shield?
Its been that way since I got it.
1958 3100 Apache 327 engine
1958 3100 Apache Panel 1/2 ton 327 engine
I don't see a fluid reservoir in the picture. If you're talking about the power brake booster, the answer is yes, and YES! Heat shields are a good thing, especially when they're protecting something you're betting your life on, like a brake system.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Thanks Jerry!
Example for a simple heat shield on single exhaust.
Ahhhh yes!! And the ever popular cookie sheet drip pan!!!! Lol.
1949 gmc 1-ton
It’s actually an official drip……………the wife repoed her cookie sheets.
Nice!! I ended up with pipe wrap and shield. Did the donuts and down close to
the power steering. Also underbed.
Shield is hard to see....
You can some discoloration to the bottom side of booster.
Moderated by  SWEET
