The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (D B Cooper, 29tons, 55_2nd_Series, EdPruss, baldeagle, 1 invisible), 113 guests, and 3 robots.
Forums60
Topics124,607
Posts1,005,710
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
63 GMC 305 v-6 distributor question
#1406670 Mon Apr 19 2021 03:19 PM
I have a 63 GMC pickup with a 305, and have noticed there seems to be 2 types of distributors for this engine. Mine has the externally adjustable points (window like v-8 distributors). I think I have seen pictures of other 305s with distributor caps that resemble in line 6 type. Anyone know if there’s a year or model changeover point? Or am I mistaken?
Re: 63 GMC 305 v-6 distributor question
BobShingledecker #1410596 Thu May 20 2021 12:35 PM
Unrepentant VW Lover
Bob -- Sorry no one knew the answer to this. It may be an after market cap? My '65 305 did not have that window. Just a straight, solid cap.
How do you get to it??? On my truck, access to the side of the distributor was very limited and made harder by the location of the distributor in the first place. Is the idea that you can adjust the points with the engine running? So you have to lay across a hot, running engine and hope you don't get any flaming backfires through the carb right in your belly? Yikes.
"Of all tyrannies a tyranny sincerely exercised for the good of its victims may be the most oppressive."
— C. S. Lewis
'49 Chevrolet 3804
BobShingledecker #1410604 Thu May 20 2021 12:57 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
John, regarding your “How do you get to it” question. Before starting the engine you would raise the side cover of the distributor, it should stay up on its own. Then start the engine and connect up your Dwell/Tach Meter. There was a specialty tool made to insert into the adjustment screw attached to the points. It was a long spring with a screwdriver handle on one end and the proper size Allenhead wrench on the other. A regular Allen wrench could be used but it was a real pain. You would then turn the driver left or right to adjust the points thus setting the dwell. The tool (I still have one) was about 10” long. Then pull the tool and close the little sliding door.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
BobShingledecker #1410674 Thu May 20 2021 08:29 PM
Sir Searchalot
To follow up, He asked his question over on 6066GMCCLUB and got the answer.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
Justhorsenround #1417555 Tue Jul 20 2021 10:07 PM
Martin over 50 years ago I just made an allen wrench distributor key and carried it with me,adjusted a lot of those.
BobShingledecker #1417566 Tue Jul 20 2021 11:01 PM
There's a shade tree trick on those external-adjust distributors when a dwell meter isn't available- - - -with the engine idling, turn the adjustment screw clockwise until the engine stumbles or stalls, then back off 1/2 turn. The dwell is set within specifications. I've also got one or two of those flex cable adjusters stashed away somewhere.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Hambone
