https://www.summitracing.com/parts/wlk-36516I used these Walkers on my C10. They are a great price, and the 6 I bought are very solid. I will be getting these for my 50 1/2 ton as well. You won’t be disappointed, but you do have to weld them onto the pipe.
Bolt on- no, welding required.
Quality- YES.
Easy install- that’s relative.
Alternatively, similar to Kevin’s suggestion, I have also used these:
https://www.autozone.com/emission-c...ilt-universal-tail-pipe-hanger/59032_0_0Bolt on- yes
Quality- depends on brand?
Easy install-yes
However, the rubber tore on my 1 ton and I had to replace the hangers. I haven’t got around to it, but I might use the walkers I mentioned above on my 1 ton in the future.
Get a quality hanger, whatever you do, and you’ll be good!
