The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (WE b OLD, Garageguy6078), 77 guests, and 4 robots.
Forums60
Topics129,208
Posts1,047,827
Members46,222
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
WarEagle1 #1417372 Mon Jul 19 2021 01:04 AM
Unrepentant VW Lover
Back to the OP ...
We had one of our dump trucks at work just blow a tire sitting parked in the yard last week. As you can see, plenty of tread left. Just blew. Older tire ... So don't let tread wear be your only guide.
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
'49 Chevrolet 3804
'73 IH 1310 Dump
'14 Ford E-350 4x4 (Quigley)
WarEagle1 #1417417 Mon Jul 19 2021 08:34 PM
Somewhat related - I was filling a rear tractor tire with air. Was an old Ford 800 series - finished putting air into it - went around the other side to do the same - and all of a sudden KABLAMM! my ears hurt, and the sound echoed across the road and down aways. Went back to inspect - and the steel rim was missing a chunk and it was twisted at one spot and the tire was well, not able to hold air anymore. It sounded like three shotguns went off at the same time....goes to show - old rims filled with calcium chloride rust from within. I had acquired the tractor about a month prior and didn't know the maintenance history of it.
Lucky to be typing this story today - I cant imagine being bent over next to it when it let go and exploded sending a chunk of steel across to the other side of the tractor shed.
WarEagle1 #1417438 Tue Jul 20 2021 02:04 AM
Back when I was running a roadside service truck and doing tire service on big rigs, I had what I called a "Chicken Line"- - - - -a 25 foot air line with a clip-on chuck and a ball valve and a pressure gauge on the other end. Even with a tire secured inside a safety cage I would hide behind something sturdy while airing up tires. For a really sobering thought, figure out how many square inches are in the sidewall of a big rig tire, multiply by 120 PSI, and calculate how many TONS of force are pushing out against that bead ring!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
WarEagle1 #1417554 Tue Jul 20 2021 10:03 PM
Back in 1965 had tire/rim explode on a friend of mine. Can't describe the condition of his jaw/teeth but to this day you know something went terribly wrong......nuff said.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
1952 Chevy Panel [photos.app.goo.gl]
[photos.google.com]
Page 2 of 2 1 2
Moderated by  Justhorsenround
