New truck forum
New Forum Added in Parking Lot
EARLY BOLTS
1916 - 1936
1928 Chevrolet AB Canopy Express
"Justin"
Discussing issues specific to the pre-1937 trucks.
Searching the Site
2023 Old Truck Calendars
Second one
Sweet-looking old Stovebolts
2023 Stovebolt Calendars
Check for details!
11 members (68ironhead, Daves46pu, Gdads51, cmayna, DonBolt, 55_2nd_Series), 236 guests, and 3 robots.
Forums64
Topics122,552
Posts989,032
Members46,958
Most Online1,229
Jan 21st, 2020
Here is a pic of the distance from my exhaust pipe and brake res. mounted to
frame.
Is this too close and should I put up a heat shield?
Its been that way since I got it.
1958 3100 Step side Apache 327 engine
1958 3100 Apache Panel 1/2 ton 235 engine
1959 3100 Apache Panel 1/2 ton 327 engine
I don't see a fluid reservoir in the picture. If you're talking about the power brake booster, the answer is yes, and YES! Heat shields are a good thing, especially when they're protecting something you're betting your life on, like a brake system.
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
Thanks Jerry!
Example for a simple heat shield on single exhaust.
Ahhhh yes!! And the ever popular cookie sheet drip pan!!!! Lol.
1949 gmc 1-ton
It’s actually an official drip……………the wife repoed her cookie sheets.
Nice!! I ended up with pipe wrap and shield. Did the donuts and down close to
the power steering. Also underbed.
Shield is hard to see....
You can some discoloration to the bottom side of booster.
