The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (buoymaker, Spotbiltxo, Squire, Luray, 2 invisible), 100 guests, and 3 robots.
Forums60
Topics127,519
Posts1,032,226
Members45,797
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'47 1.5ton - can I change front spindles?
#1416888 Tue Jul 13 2021 10:33 PM
In reading all of the options for "correct" wheels and tires - I really don't want to spend the money on obscure tires for these obsolete 3-piece wheels. I'd much rather have a modern all-terrain setup. Something like a 8x170 pattern.
So can I change just the (forgive me if my terminology is wrong) 'spindle' on the front? It looks like it is just bolted to the brake drum. If so, I'd just do that, and swap in the rear axle from the busted-transmission '00 F250 in my driveway. Or would it make sense to just go ahead and swap the front too, to something with discs?
Plan for the rig is more of an occasional driver / work truck, not a garage queen.
Re: '47 1.5ton - can I change front spindles?
Capt Oblivious #1416921 Wed Jul 14 2021 03:28 AM
9
Captain if I was doing this,I would only update to 50's Bendix brakes,drums r ok if set up correctly
Karl j Townsend
Capt Oblivious #1416975 Wed Jul 14 2021 07:53 PM
The "spindle" is the entire shaft that the hub spins on, all the way to the pivot on the axle called the "kingpin". That 8-bolt circle you're looking at is an adapter that holds the outer wheel bearing and spaces the wheel center out to the right width to be compatible with the dual rear wheels. No, it cannot be removed without some very involved (and expensive) machine work to fabricate a wheel mounting flange with a different lug bolt circle.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Capt Oblivious #1416979 Wed Jul 14 2021 08:03 PM
Hotrod, I guess that's what I needed to know, thanks!
Capt Oblivious #1417045 Thu Jul 15 2021 12:59 PM
That bolt pattern is referred to as 5/10, 5 studs on the front and 10 on the rear, 10 on 7.25” circle. Wheels to fit these are rare 22.5” and common 19.5”. Dana 70 and 80 rear axles come with this pattern. 19.5 tires look slightly small to the rest of the truck, but are available.
One can fit modern disc brake spindles and hubs to 2 ton front axles, read Grigg’s articles on that subject here.
Ed
Capt Oblivious #1417128 Thu Jul 15 2021 11:15 PM
Yep, I've read Grigg's extensive research on the subject - I just felt that outer adapter was something that was either ignored or not considered.
As my truck has all-original engine, trans, axles, brakes, etc - I'm just trying to wrap my head around the idea of an axle swap. I'm just not really jazzed about spending $1500 on six 8.25-20 tires, since they're not really what I want anyway.
Capt Oblivious #1417153 Fri Jul 16 2021 04:18 AM
With a little (OK- - -a lot) of creative machining, adapter rings could be added to those hubs that would accommodate the 10 lug Budd wheels found on modern big rigs. A bunch of the butchered-up later model trucks at the Lebanon Tennessee show over the weekend were running wheels with that style of center on pickups. They looked ridiculous, but "Different strokes for different folks!"
Kris Kristofferson
Moderated by  69Cuda, Grigg
