The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
Set of .060 over pistons with rings for 261 chevy. The rings have less then an hour of run time on them. Engine block was cracked. 125.00 plus shipping
Do you still have the block? If so, where are you in Tennessee, and what would you want for the piston/block combo. I can do a "no-shipping" pickup, most likely. Thanks! Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson
