The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Hookalatch, fonz8261, Dongray, bsarts, Bruce36 1.5, 1 invisible), 145 guests, and 3 robots.
Forums60
Topics124,655
Posts1,006,157
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
whats the correct way to fix this
#1416631 Sun Jul 11 2021 07:18 PM
29tons Offline OP
My cab took a pretty hard hit on the back roof area at the rear window. I was wondering what the best way to fix this.
Re: whats the correct way to fix this
29tons #1416655 Sun Jul 11 2021 11:20 PM
Hammer & Dolly and lots of time
Mason
1947 Chevy 3100
-57 Chevy 235
-93 S10 T5 Transmission
-97 Blazer 3.42 Rear End
29tons #1416692 Mon Jul 12 2021 12:17 PM
AD Addict
I believe that dent is partially hidden by the inner roof panel. A stud welder and slide hammer would be your best bet, but you may be able to pry from the inside with a flat bar (while tapping down the high spots), with the end ground smooth so you don’t leave dimples.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
29tons #1416734 Mon Jul 12 2021 05:54 PM
The HB stud welder works well enough and is cheap.
29tons #1416758 Mon Jul 12 2021 08:47 PM
Sir Searchalot
I don't know what HB is? HF?
Anyway the "best way" is the way YOU can do it. If it has access on the inside, it's a no brainer. If not, I could not pull it out without being able to dolly it back down because you can't pull it to original shape. At least I could not. It would have highs and maybe lows after pulling. You can't get rid of the highs unless you have a lot of experience and tools. I think the idea is to pull it almost back up and then fill. Don't create any protrusion.
I would have to cut the piece out, shape it and weld it back on. Been there, done that. Works for me.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
I used to think beer was bad for me, so I gave up thinking.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
29tons #1416765 Mon Jul 12 2021 10:15 PM
Yes, HF. Fatfingered.
Moderated by  HandyAndy, klhansen
