The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 103 guests, and 3 robots.
Forums60
Topics124,970
Posts1,008,598
Members45,105
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
In need of front wheel bearing upgrade.
#1416283 Thu Jul 08 2021 02:58 AM
Elmo Offline OP
I have a 53 Chevy 3600. I am having a heck of a time trying to find the front wheel bearing upgrade for the 3600 3/4 ton trucks.
Can anyone help me out?
Elmo.
Re: In need of front wheel bearing upgrade.
Elmo #1416287 Thu Jul 08 2021 04:41 AM
Why "upgrade" a design that has worked well for over 75 years? The myth that tapered roller bearings are somehow better than ball bearings doesn't have much proof behind the fantasy. If you simply must make a change just for the sake of following the crowd, find one of the progressive size charts that all bearing manufacturers publish and do some measuring of the original bearings. If you can find an outer bearing race("cup")that will fit the bore of the hub, a good machinist can make an adapter sleeve to make the "cone" fit the spindle. You'll also need to find a grease seal that can be fitted to the hub, and have a sleeve made for the seal lip to ride on, since the original equipment ball bearing has the seal surface built into it.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Elmo #1416292 Thu Jul 08 2021 09:50 AM
I upgraded my 49 150’s wheel bearings by packing them with new grease from the latest century. 72 years old and look absolutely perfect 👌. I regularly cruise at 70mph for hours with zero issues.
Elmo #1416399 Fri Jul 09 2021 02:38 AM
Elmo Offline OP
If what I have in my truck is the way to go, I will just keep what I have. If it ain't broke, I'm not gonna change anything. It's always good to know what's good or bad. And I thank you both for the information.
Elmo
Elmo #1416436 Fri Jul 09 2021 02:30 PM
I looked into that as well on my '53 3600 with no success my bearings an races were in great shape so that's what is going back in.
Elmo #1416485 Sat Jul 10 2021 01:49 AM
If I have to replace a bad set of ball bearings, I buy roller bearings as replacements The new ball bearings are priced a bit high.
The last two trucks I changed out, I went ahead and bought the hub/bearing/seal kit. They are nice, and all you need to do is pack the bearings and install the hubs.
No hammering out old races required.
Hotrod Lincoln #1417734 Thu Jul 22 2021 01:13 PM
Hotrod Fully agree with your take on bearings,need to leave em alone mine are over 70 yrs. old now . run good !!
Elmo #1417742 Thu Jul 22 2021 02:36 PM
Two years ago had to do some work on an Audi, the owner wanted the wheel bearings changed. Perfect ball bearings and it was a newer auto. The Allied Forces found late in WWII that if we concentrated on the ball bearing factories in Germany we could bring them to their knees. My 1940 Plymouth truck has perfect ball bearings that I don't believe were ever changed according to the original owner. Nuff said. Doc.
Elmo #1417745 Thu Jul 22 2021 02:55 PM
Roller bearings must be cheaper to produce than ball bearings. I have to think chopping a long rod into pieces is easier than making a perfect sphere. I've always thought that's the reason behind the shift to rollers.
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Elmo #1417751 Thu Jul 22 2021 04:11 PM
Curmudgeon
All the bearing information we need to know is available in books, on the Internet and in classrooms in engineering schools.
The different type bearings are engineered for a purpose (or application). It requires the effort to study.
Be skeptical about the media hype, magazines and the "hot new" stuff you read about.
You can get sidetracked into buying something you don't need or worse installing something inferior.
Page 1 of 2 1 2
Moderated by  Justhorsenround
