The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Bruce36 1.5, 3B, Maddoggee1959, gswbbc, dgrinnan, 1 invisible), 125 guests, and 3 robots.
Forums60
Topics124,653
Posts1,006,150
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Anti freeze smell.
#1415620 Fri Jul 02 2021 09:45 AM
After I changed the thermostat in my 1954 235 I have had the smell of antifreeze and the level when I top it off the water level drops to just above the core. I don't have an overheating problem and never have since I put a new aluminum one in 13 years ago. I also have the smell of antifreeze in the cab. ??????
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: Anti freeze smell.
WE b OLD #1415625 Fri Jul 02 2021 11:55 AM
AD Addict
Do you have a heater in the cab? If so it or the hoses may be leaking.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
WE b OLD #1415633 Fri Jul 02 2021 01:45 PM
I have an after-market A/C heater combo and I have not found any damp spots. The smell does not become evident until the engine warms up.
2017 Buick Encore
Pix on Photobucket
WE b OLD #1415636 Fri Jul 02 2021 02:02 PM
What kinda overflow are you using if any?
WE b OLD #1415638 Fri Jul 02 2021 02:53 PM
Must have some overflow on the radiator coils that need to burn off.
1958 3100 Apache 327 engine
WE b OLD #1415641 Fri Jul 02 2021 03:43 PM
Curmudgeon
Why did you change the thermostat?
WE b OLD #1415737 Sat Jul 03 2021 08:49 AM
To get more heat in winter. The overflow idea has merit. I have one of those caps that have the relief lever on the top and it was not seating properly. That could be the problem and someone suggested that I should wash the area down.
2017 Buick Encore
Pix on Photobucket
WE b OLD #1415754 Sat Jul 03 2021 01:42 PM
Fluid level might change with a different thermostat. I took my relief cap off.
Put on a cap ..I think its 14lbs rated.
WE b OLD #1415770 Sat Jul 03 2021 03:38 PM
The only reason to run a high pressure cap is so a vehicle with a tiny radiator can let the coolant get very hot without boiling over. Most modern cooling systems run between 195 and 230 degrees or so, and run anywhere from a 14 to a 17 pound cap. Most stovebolters get a case of the vapors and need a fainting couch if their coolant gets above 200 degrees. Since the boiling point of the coolant rises 3 degrees for every pound of pressure, even a 7 pound cap raises the boiling point to 233 degrees at sea level. A 15 pound cap takes the boiling point to 257 degrees. All a high pressure cap is good for on a mid-1950's or older truck is causing radiator and/or heater core leaks.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
WE b OLD #1415796 Sat Jul 03 2021 09:32 PM
Curmudgeon
To get more heat in the winter, for the engine coolant temperature or because it's cold inside the cab or both?
Adding a UV dye and using a UV lamp may help locate leaks. I've never tried it myself.
If you have closely inspected everything that was touched during the replacement and found no leaking, I would start thinking about things that may be affected by the increased temperature.
May not be the problem you have:
These engines, after many years, tend to collect rust in the coolant passages around #6 cylinder. If severe, it can cause that portion of the engine to overheat.
It happened to my cousin in a stock 50 Chevy. The car was a daily driver to and from work. He took it on a long vacation trip. It overheated.
The increased heat from the trip caused the rust to migrate. He flushed the radiator and the block several times. Luckily it finally cleared out.
The return home trip was normal.
Page 1 of 2 1 2
Moderated by  Woogeroo
