The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (dgrinnan, Johnny N, Flatblu4748, drware, lumbersawyer, 3B), 128 guests, and 3 robots.
Forums60
Topics124,653
Posts1,006,149
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Speedometer question 49 3100.
GradyB #1412886 Sun Jun 06 2021 07:00 PM
I also think that rear bearing support is held in place by a small bolt on the top of the transmission or maybe on one side of it. I'll look to see if I have anything on this in my old notes.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
GradyB #1413487 Fri Jun 11 2021 01:11 AM
GradyB Offline OP
I have had a chance to pull the driven gear from the side of transmission to inspect it. It shows a couple of miner nicks but nothing major. The teeth look ok. Is the rear bearing support located in the transmission? Not looking forward to taking all that apart again. I haven't driven it since its been inspected but will this weekend. Thanks for all the support. I will figure this out, sometime.
GradyB #1413896 Mon Jun 14 2021 08:03 PM
GradyB Offline OP
Took truck for drive and speedometer still does the same thing. I think too it has to be something inside that's not correct. It works somewhat ok until everything gets up to temperature. Then as I step on gas speedometer goes to zero. If I let off it jumps up to correct speed. Guess I'm gonna have to take things apart.😬
GradyB #1413979 Tue Jun 15 2021 02:32 PM
This sure is an odd one. So when cold, if you step on the gas, the speedo works?
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
GradyB #1414113 Thu Jun 17 2021 01:06 AM
GradyB Offline OP
No when I step on gas it goes zero, quits working. As I let off and coast it goes to correct speed.
GradyB #1414114 Thu Jun 17 2021 01:07 AM
GradyB Offline OP
When cold it works about 1/2.
GradyB #1415486 Thu Jul 01 2021 02:14 AM
Well when you see red and blues, let off da gas, and youll know if they're after you. ohwell
Page 2 of 2 1 2
Moderated by  SWEET
