The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (1 invisible), 100 guests, and 3 robots.
Forums60
Topics124,970
Posts1,008,598
Members45,105
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1954 235 rocker arm push nuts.
#1414517 Tue Jun 22 2021 12:17 PM
Elmo Offline OP
[img]https://www.stovebolt.com/ubbthread...ame/16243694666743798942508483389441.jpg[/img]On top of the rocker arm lock nuts there are also a spring steel push nuts. That I assume helps keep the lock nuts from loosing up. I took off the valve cover to adjust the rockers and noticed that three of those push nuts had fallen off. Do I need these to be there? And if so, where to buy new ones?
Thanks in advance.
Elmo.
Re: 1954 235 rocker arm push nuts.
Elmo #1414519 Tue Jun 22 2021 12:30 PM
AD Addict
Can’t say I have ever seen spring nuts on top of the rocker adjustment nuts. My ‘59 235 does not have them. Maybe thats why their coming off.
Can you post a picture of the rocker with the spring nuts installed?
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Elmo #1414532 Tue Jun 22 2021 03:13 PM
Those are called Pal nuts, are used on aircraft, external places, not on internal locations, among other places. Not required on rockers, small enough to be sucked into dangerous places.
Ed
Elmo #1414534 Tue Jun 22 2021 03:16 PM
They're called "Pal-nuts", and they aren't original equipment. Pitch them into the nearest circular file and don't bother to reinstall them. They're used on 235 connecting rods in some applications, and they're also worthless there, although Chey did use them as OEM for some silly reason.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Elmo #1414538 Tue Jun 22 2021 03:49 PM
Wow you want to get rid of them. If they came off they could make an awful mess.
1951 1 Ton Completed
Elmo #1414539 Tue Jun 22 2021 04:18 PM
Ditto to ather responses. Be gone with em. Extra unnecessary parts gettin flung around in there is not an ideal situation.
Elmo #1414541 Tue Jun 22 2021 04:31 PM
Elmo Offline OP
I will remove them tonight and discard. They were there when I bought the truck.
Elmo #1414953 Sat Jun 26 2021 12:40 AM
I wonder if the pal nuts were deemed necessary to keep the connecting rod dippers in place, then continued using them on the later 235s just because.
Elmo #1414956 Sat Jun 26 2021 01:03 AM
Probably not- - - -the PAL nuts wouldn't have enough strength to retain the dippers- - - -they're always installed between the rod nut and the cap. The force of the dipper hitting the stream of oil several times a second would rip the sheet metal nuts off.
Elmo #1414982 Sat Jun 26 2021 02:32 PM
Isn't it amazing what we sometimes find both in and out of old engines. I believe the reason is due to some folks believing that simplicity of an engine meant simple applications. Maybe Jerry can go on the Greasy Spoon and elaborate, he has to have some interesting stories. Ed
Page 1 of 2 1 2
Moderated by  Woogeroo
