The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (55shaker, 2ManyTrucks, Bolter Finally, 1942-G506, 52Carl, 1 invisible), 127 guests, and 3 robots.
Forums60
Topics124,641
Posts1,006,005
Members44,990
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Adding a Dump Box?
#1413016 Mon Jun 07 2021 07:43 PM
Goach2 Offline OP
Hi all,
I have a line on a dump box from a TF truck
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/32109/filename/Dumper.jpg[/img]
Has anyone added a dump box to a frame that did not have one originally? I have a 3600, but am curious if I would have to cut out cross members to make this work? I will be pulling the transmission in the near future, so adding the pto can be done then, but I won't bother if it's too evasive to do.
Thanks!
1948 Chevrolet Thriftmaster 3/4 Ton
There are only 10 types of people in this world, those who can read binary and those who can't.
Re: Adding a Dump Box?
Goach2 #1413023 Mon Jun 07 2021 08:54 PM
3B Offline
Hy Goach2, it looks like the frame for the dump box hydraulics is sitting inside the frame of the truck it is on, we can't see both sides of it from your picture, but if it the same on both sides it may have to be removed with a cutting torch. I've never seen one like that before, most dump frames sit on top of the trucks chassis, not inside of it, I'd steer clear.
Goach2 #1413094 Tue Jun 08 2021 01:49 PM
Goach2 Offline OP
Thanks 3B, I was thinking the same, plus my frame has the wheel 'hump' and I don't know how it would work with this set up. Is it worth grabbing the hydraulics? Or just wait for something complete AND compatible?
Goach2 #1413124 Tue Jun 08 2021 04:20 PM
You could look into one of the modern electric over hydraulic systems like this one. By the time you buy a PTO to fit your SM420 and rebuild an old hydraulic pump system you may be money ahead.
https://www.piercearrowinc.com/prod...jvjpV8BmThrNEmsRIUrYUMa1nlRoCuGcQAvD_BwE
Mike B smile
Goach2 #1413500 Fri Jun 11 2021 03:09 AM
Goach2 Made a 4 ton dump box out of oil tank steel for my 48 2 ton,not easy but works fine. Tank steel never forgets it was round but you can overcome that with your torch and arc weldor.
Goach2 #1413859 Mon Jun 14 2021 06:05 PM
Goach2 Offline OP
Fixite7 - I'd like to see that!
Goach2 #1414450 Mon Jun 21 2021 04:00 PM
Goach2 Put on a picture of my 51 6400 daily driver,maybe you saw it. My posts disappear a lot,Martin says trouble is with my computer I think he is right. Im no 'puter gooroo ! If I can get a handle on pictures will show that bed. If not could maybe send you some phone pictures,they PM but not sure how to do that either. My 51 6400 has a tank steel bed too,picture is not very good.
Goach2 #1414997 Sat Jun 26 2021 04:11 PM
Goach2 Hadn't heard anymore from you,if you can receive pictures call me 618 707 9582 will try to send you some pictures of that gravel bed. Handles about 8000 lbs of white rock,your frame looks like a candidate foor the same thing. Gross about 15000 E.W. 7000.
Moderated by  Justhorsenround
