The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (52Carl, Old Tractor Guy, Wayne67vert, Dusty53, morerog), 163 guests, and 4 robots.
Forums60
Topics124,729
Posts1,006,721
Members45,019
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Bed to frame install
#1414199 Fri Jun 18 2021 11:59 AM
Do any of you have the info on bed mounting blocks location and number of rubber spacers required, etc. for a 1950 3100? I'm hearing conflicting info.
Re: Bed to frame install
Rocket man #1414200 Fri Jun 18 2021 12:13 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Search Mar-K’s website. I believe the info you need is there.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Rocket man #1414201 Fri Jun 18 2021 12:15 PM
AD Addict
Here is a link to mar-k. [LINK] [mar-k.com]
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Rocket man #1414207 Fri Jun 18 2021 01:33 PM
Hi Rocket man,
I also found a lot of conflicting information when I was re-doing the bed of my '47. Even the kits available will have different numbers of blocks and spacers. There are six mounting points on the 3104. You will need six rubber pads (spacers) and four wooden blocks. My '47 has three fixed cross sills and one floating cross sill that is notched for the under-bed gas tank. The front and middle cross sills will use the wooden blocks and rubber spacers. The rear cross has a 'steel block' so you'll need rubber spacers in this position. All three mounting points should be the same overall measurement from the frame rail to the underside of the bed, in order for the bed to sit level on the frame.
I've come across information that indicated there are four fixed cross sills on the 3104; however, many trusted SBs indicated this was incorrect. Check out the Making a Stovebolt Bed forum for additional information.
Good luck,
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
