The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (dgrinnan, Leo, Harold46, Justhorsenround, Dusty53, panel fan), 120 guests, and 3 robots.
Forums60
Topics124,606
Posts1,005,699
Members44,983
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Might be time for wheels
#1414177 Fri Jun 18 2021 01:15 AM
Hi Folks,
I replaced my 30 yr old Cooper tires on my 1954 Chevy 3100, and my local tire shop did not have such a good time.
- First they did not think they had any valve stems that would work, but as it ended up they did, and they worked just fine
- Then they had a heck of a time spin balancing them. but they got it done (to a point)
- Then while putting wheels on, they were torqueing the wheels down, they felt the lug nuts were going through the wheel, so they replaced them with bigger once at no charge.
- They are recommending that I replace the wheel studs, as they did not feel they were safe.
So I need to take the wheel off, and look at the studs, and find a shop that can replace them all
Lastly, I love my wheels, but wonder if I should be looking to get a new set, that look like mine.
I have attached a picture
Any know where I can get wheels that look like this?
1954 Chevy 3100
Re: Might be time for wheels
Kevin13Shaw #1414187 Fri Jun 18 2021 03:12 AM
They look pretty fine to me.
Ed
Kevin13Shaw #1414194 Fri Jun 18 2021 06:07 AM
they look like the typical spring hubcap vintage wheels used for tons of years. mine are 6 lug 16's on my truck. if buying just be aware there are several widths. my truck came with 3 different ones so I'm looking too. nice trim rings and hubcaps!
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Kevin13Shaw #1414291 Sat Jun 19 2021 04:21 PM
If your studs withstood the torque they use now days your studs are fine. Wheel stud holes do waller out some over the years but I've never had any problem and you say they used lugnuts with a little bigger heads....you should be good to good and probably safer than some of the spacers and offsets that are on the road!!
...keep it under a 100mph and you should be good....... ..just my .02
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Kevin13Shaw #1414491 Tue Jun 22 2021 12:52 AM
They probably put “big bulge” lug nuts on it. Thats what I run on my 16” ford wheels too. They work great.
Moderated by  Justhorsenround
