The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Hotrod Lincoln, DennisM, Forty9, mo2cyl, Christian, 2 invisible), 121 guests, and 3 robots.
Forums60
Topics124,634
Posts1,005,948
Members44,985
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: electric wiper replacment
woof359 #1413668 Sat Jun 12 2021 09:31 PM
I've only installed a couple but the NewPort Engineering was great....and if you order correctly will miss the choke wire.
.....sadly its to late for Woof, he's already spent his money.
...not sure if JCarter still sells the Newport unit but I purchased mine from him cheaper than I could buy it directly from Newport....but that was a few years ago. (about 5)
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
woof359 #1413670 Sat Jun 12 2021 09:39 PM
If you get tired of only having 2 speeds (and if your truck is a daily driver and you're not worried about driving in the rain), you might want intermittent wipers someday. If so search and you'll find the circuit I posted a year or two ago making this all possible. You can even select the amount of delay when you're building the circuit.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
woof359 #1413672 Sat Jun 12 2021 09:55 PM
Sir Searchalot
Counterpart seems to be a huge wholesale company. Probably Chinese. No website when g o o g l e d. Classic parts does identify which are USA made and you can see the Newport logo on some.
Some 12V on Classic site are not labeled USA, so those would be the "off shore". As said, none of the 6V say USA made and Newport does not have a 6V unit. Newport mentions knob modification.
Some off shore stuff is good , some are not.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
woof359 #1413677 Sat Jun 12 2021 10:08 PM
Counterpart is the wholesale side of Car & Truck shop out of orange, CA. They are importers of many truck parts and wholesale to a lot of retailers. Some of their stuff is good and some crap. WES
The above was copied and pasted from the site: www.67-72ChevyTrucks.com [67-72chevytrucks.com]
It was posted about 10 years ago and a discussion followed on that site...as you might expect.
There are lots of comments floating around about these two operations. I suppose you can make up your own mind.
Jon
bartamos #1413684 Sat Jun 12 2021 10:59 PM
I agree.
1949 gmc 1-ton
woof359 #1413685 Sat Jun 12 2021 11:16 PM
Sir Searchalot
Bottom line after all this is:
Woof359: Good job on making it work and thanks for the info.
woof359 #1413697 Sun Jun 13 2021 02:14 AM
My Newport installation went OK, some parts missing, promptly replaced, directions sort of vague.
Might be easier with a 6 volt truck to use a resistor and 12 v unit.
Ed
woof359 #1413704 Sun Jun 13 2021 03:46 AM
Would not trade my vacuum motor for a dozen electric. Sent my motor to Ficken about 40 years ago and then put an electric vacuum pump from a Mercedes diesel where the battery box used to be. Has UNLIMITED number of speeds and is unaffected by pull on engine so no stop going up hills. I guess with an electric vacuum pump it could be called a "hybrid".
Evan
woof359 #1413758 Sun Jun 13 2021 08:11 PM
woof359 Offline OP
didnt see any foot notes on cable clearance, no biggie, new cable works so much better, yes the chrome plastic knob has a set screw, only one wire to hook up the wiper, missed the posts on others wiper installs. got it in, no rain expected for the next decade here just HOT and sunny, well go look for the other wiper post, Many Thanks
woof359 Family 1952 3100 5 Window
woof359 #1413772 Sun Jun 13 2021 10:21 PM
Sir Searchalot
Good deal. Maybe there was no note about the choke cable. But I don't really know who you bought it from. The note I am referring to is at the bottom of This page. [classicparts.com]
Page 2 of 3 1 2 3
Moderated by  Rusty Rod
