The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (BernieB, coilover, Donf, 55shaker, asilverblazer, 2 invisible), 108 guests, and 3 robots.
Forums60
Topics126,133
Posts1,019,636
Members45,442
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
63 305 V6 Bucking
#1413659 Sat Jun 12 2021 08:41 PM
Moderated
Hi, I have a 63 3/4 4x4 with the 305E that started bucking. I tuned up everything including new points, condenser, cap etc. Had the original Stromberg carb rebuilt and still having issues. I love that it's all original so don't want to do the holly carb thing.
Any feedback appreciated.
Rob
1963 gmc
Re: 63 305 V6 Bucking
Oldgmc1963 #1413678 Sat Jun 12 2021 10:09 PM
Curmudgeon
If you didn't check your fuel tank for rust (ethanol and old tanks = rust) and did not replace your fuel filter, the rebuilt carburetor could now have contaminants inside.
Check your fuel pump pressure or replace.
Check for vacuum leaks (carburetor to intake, vacuum lines/hoses, distributor timing advance diaphragm).
Replace coil.
buoymaker #1413682 Sat Jun 12 2021 10:40 PM
Moderated
thank you for the quick reply. Yes, did coil, plugs wires, cap, everything and fuel filter when the carb rebuilt. Fuel pump is about two years old but I probably haven't driven 300 miles. I'm no expert but when a pump goers it goes. I also left out that when I start it after she sits, runs perfect and then seems to happen 20 minutes into driving her.
1963 gmc
Oldgmc1963 #1413692 Sun Jun 13 2021 01:50 AM
Possible item in fuel tank?
Ed
Oldgmc1963 #1413694 Sun Jun 13 2021 02:03 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Crud in the fuel tank moving around occasionally covering the pickup.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Oldgmc1963 #1413698 Sun Jun 13 2021 02:19 AM
Curmudgeon
It's not a procedure I would recommend without extra precaution to be safe....but....you could rig up a test fuel container and connect to the fuel pump.
The Stromberg WW has a good reputation.
Do you have a vented gas cap?
Oldgmc1963 #1413702 Sun Jun 13 2021 03:30 AM
Insomniac
Stuck heat riser?
Gord
1954 1/2 ton 235 4 speed
Oldgmc1963 #1413705 Sun Jun 13 2021 03:51 AM
Try rigging up a temporary fuel tank, like one for an outboard motor, and be sure it's well vented. Then take a test drive. I'm going to guess you're getting a vacuum in the tank after a few minutes of driving that's causing the engine to surge. You might have the wrong type of gas cap, or a clogged vent tube.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Oldgmc1963 #1413716 Sun Jun 13 2021 05:47 AM
Sir Searchalot
I will never ceased to be amazed at experienced Stovebolt folks firing off a bunch of ideas from just the word "bucking".
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
I used to think beer was bad for me, so I gave up thinking.
Sometimes no nonsense makes sense, in a sense.
You can't teach a new dog old tricks.
Honk if you're Amish
Oldgmc1963 #1413722 Sun Jun 13 2021 01:19 PM
Moderated
Ditto. thank you all. Have some homework to do.
1963 gmc
Page 1 of 3 1 2 3
Moderated by  Woogeroo
