The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Hotrod Lincoln, EdPruss, ASU, DennisM, jasrking, 1 invisible), 231 guests, and 3 robots.
Forums60
Topics123,437
Posts996,198
Members44,665
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Parking brake - 1951 3100
JW51 #1411715 Fri May 28 2021 01:45 PM
AD Addict
Kevin, the cable you show on the right, although an improvement, especially if it fits the frame bracket, it still not the correct cable.
The correct cable has a turned end, with two cylindrical radiused grooves. One for the cable boot and the other for the bracket bolt that locates the cable correctly in the clamp. This interfering bolt also stops the cable from moving in the clamp if the bolt happens to loosen. A second fail safe for your emergency brakes.
I bought mine from LMC Truck, item # 34-3806. Just checked, and still in stock and priced at $19.95 each..
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
JW51 #1411750 Fri May 28 2021 05:26 PM
Phil
I do recall the original cables on my truck (completely frozen and long gone) had at least one groove on a solid metal thimble. As far as the bolt loosening, that's not likely, but being more positive in positioning and securing is a good thing. I may return the ones I got from The Filling Station and get those from LMC. Quite a price difference as well.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
JW51 #1413507 Fri Jun 11 2021 04:36 AM
So I currently have 3 styles of parking brake cables: the AC Delco pair from RockAuto that are vinyl covered and don't fit the frame bracket; Original style steel spiral wrapped cables that are REAL CLOSE to original, from The Filling Station, but don't have the notches for the bolt thru the frame bracket; and a pair from LMC Truck that are a combination, vinyl covered, but with a proper sized spool with notches where the frame bracket goes thru. The latter ones are the ones I'll be using. Function trumps appearance.
Page 2 of 2 1 2
Moderated by  SWEET
