The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Ga92009, klhansen, MNSmith, Brian Wise, Harold46, Hotrod Lincoln), 84 guests, and 3 robots.
Forums60
Topics127,511
Posts1,032,073
Members45,794
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Rim-Tire combos
John L. #1420974 Tue Aug 17 2021 09:48 PM
Hey John do you still have those inner wheels and would you be willing to part with them? Thanks
1957 Chevy 3800
Re: Rim-Tire combos
FLOregonian #1421029 Wed Aug 18 2021 02:07 PM
Sorry, Already sold them.
Re: Rim-Tire combos
Fox #1427670 Sat Oct 23 2021 04:27 AM
Moderated
Are your wheels hub centric for that year or stud centric?
1963 Chevrolet C30
Re: Rim-Tire combos
jrich #1437216 Fri Jan 14 2022 06:55 AM
Moderated
I now have over 5000 kms on my rebuilt 51 Canadian 1 ton. I did rebuild and try the split rims, the ride was wobbly, but as your aware, you cannot balance the split rims. So I got rims from a 1989 ford 1 ton van at the wreckers, I put LT285/75R16 rubber on and they sit 33" high which was the same as the original height, they clear the tye rod arms with 1/2" clearance, then I had to pull the front of the rear fenders out a out a bit to achieve 1" clearance. I simply used a hydraulic bottle jack, (inside the fender) on the forward section of the rear fender, there is no noticeable difference in appearance. The truck drives great. To tighten up the steering box I used red grease, just fill the steering box with your grease gun. You have to fill it right full after driving it for a while.
Cheers,
Andymcstalbert
Re: Rim-Tire combos
andymcstalbert #1438459 Sun Jan 23 2022 07:47 PM
Cheers,
Andymcstalbert
Hi Andy,
Nice looking ride you have there. Welcome to the Bolt.
Looking forward to spring cruising with my 50 Canadian 1 Ton hopefully will see you around.
Doyle
1950 Chevrolet 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
More pix on Photobucket
You will never stop learning new things, no matter how old you are.
Re: Rim-Tire combos
jrich #1438484 Sun Jan 23 2022 10:50 PM
Unrepentant VW Lover
That *is* a nice truck, Andy. But I beg to differ on your statement that multi-piece wheels can't be balanced. Mine were balanced and it turned out great. Many miles now on new and balanced biased plies. Who says they can't be balanced????
Cisgendered heteronormative aggressor perpetrating problematic toxic ideas of Chevrolet normativity smile
'49 Chevrolet 3804
Re: Rim-Tire combos
jrich #1438550 Mon Jan 24 2022 01:25 PM
back yard wrench turner
I had my bias ply's with split rims balanced and trued. They rolled like they were on a glass surface.
Wayne
1938 1-Ton Farm Truck
-30-Stovebolt Gallery
Re: Rim-Tire combos
jrich #1438589 Mon Jan 24 2022 05:47 PM
Moderated
back when I was deciding on tires/rims, i had sandblasted and painted six original split rims. My trusted and local tire shop said that the rubber/tube with bent tube air valve combo that we selected could not be balanced. I then borrowed a set of tire with split rims from a buddy with a driver 1 ton chevy in Saskatchewan and found the ride to be wobbly, therefore I decided to go tubeless. I am glad to hear that you bolters have had success with the split. With this new found knowledge I can reconsider if I ever want to go that way. I love the 38 Wayne, and look forward to seeing your Truck Doyle. thankyou John for the knowledge to question my local tire shop. I will certainly mention this to my local tire shop.
cheers! Andy
Re: Rim-Tire combos
jrich #1438638 Mon Jan 24 2022 11:52 PM
Andy ... You bet. Another thought ... Is your shop a franchise tire shop (like Mr. Tire, etc)? A lot of us have had great success taking our multi-piece wheels and bias ply tires to tire places that service agriculture machines or big trucks (usually NOT a chain store ...). They are usually adept at handling the older styles.
Just a thought ...
'49 Chevrolet 3804
Re: Rim-Tire combos
jrich #1439081 Thu Jan 27 2022 10:39 PM
I also run a multi piece rim with tubed radial tires. I actually went to AAA auto service and they balanced them. They did use the stick on weights which I then put epoxy over them to prevent them from loosening up and falling off. I also purchased Centramitic disks to help out with the balancing. Yes, overkill! Have no issues at all!
Jim Schmidt.
Bucks County, Pa.
1953, 3804
Pix in Photobucket [s854.photobucket.com]
Page 2 of 3 1 2 3
Moderated by  Grigg
