The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (NJC, D B Cooper, LAROKE, 1 invisible), 72 guests, and 3 robots.
Forums60
Topics124,660
Posts1,006,224
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Power glide trans’ on 235’s ?
#1412998 Mon Jun 07 2021 05:54 PM
EdPruss Offline OP
Were modern powerglides(the ones one can get parts for) ever put on Chevy 235/261 or GMC small 6 cyl. engines, and if so, what bell housing/engine attachment did they use? I know they have integral bell housings.
Ed
Re: Power glide trans’ on 235’s ?
EdPruss #1413003 Mon Jun 07 2021 06:05 PM
Probably not- - - -I believe the swap to the aluminum case PG happened around 1962 or 63, which would have coincided with the change to the 194/230/250/292 engines with the V8 bellhousing bolt pattern. About the only way to mate a late PG to the early stovebolt engine would be to use an adapter plate and flex plate intended for the TH 350 transmission.
FATSCO transmission parts in New Jersey still carries rebuilding parts for the cast iron PG transmissions, and a lot of others like the Dual Range Hydramatic, the FOMOCO Borg-Warner transmissions, Packard Ultramatic, etc.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
EdPruss #1413005 Mon Jun 07 2021 06:16 PM
The engine that I'm going to put in my truck came out of a 1961 Impala. It had the cast iron powerglide with it. In the below pic, you can see the adapter plate (about 2 inches thick) that mated the powerglide to the 235. The powerglide, adapter plate, flexplate and original torque converter are still taking up space in my garage.... I switched the 235 to the original bell housing for my original 3 speed transmission.
Mike
1953 3100
1994 Chevy 1500 (Donated to charity 2016)
2002 Chevy S10 ZR2
My Restoration Adventure Blog [grayghost53.blogspot.com]
EdPruss #1413011 Mon Jun 07 2021 06:41 PM
Ed is asking about the 2nd. generation PG with the aluminum case, which was never an option on a 235/261 engine IMHO.
Hotrod Lincoln #1413015 Mon Jun 07 2021 07:33 PM
Ah, ok. I didn't pick up on that. Thanks!
Mike
1953 3100
2002 Chevy S10 ZR2
EdPruss #1413238 Wed Jun 09 2021 02:30 AM
even the cast iron powerglide for the 6 did not interchange with the cast iron powerglide for the v8. made that mistake when i had a '57 blue flame 6 with a worn out powerglide trying to do a shade tree swap at 17. The bigest thing I learned without a proper transmission jack was how heavy those things are! the guys are right about the bell housing change. as bad as I thought the powerglide was from my experiences, built right, the newer version did great in a friends chevyII drag car.
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Moderated by  SWEET
