The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (tomctomc), 105 guests, and 3 robots.
Forums60
Topics123,939
Posts1,000,194
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
V Band Clamps or Band Clamps
#1413048 Tue Jun 08 2021 01:16 AM
Found a small jar of motivation and started putting the little V8 Fun car back together. Made it to the exhaust system. In the past I've either welded all connections or used clamps. This time the plan is to not weld all joints but leave two sections (either side of the T5 transmission) unwelded and clamped in case the transmission needs to come out. Just unbolt and go.
Anyone have a strong opinion on V Band vs Band Clamps? I've never had a problem with good stainless band clamps, but it does look like stainless V Bands with the welded male/female flanges would make for a superior seal.
Not a huge factor but a first look shows V Bands being about twice the price. Making total cost about $100.00 vs $50.00 for 4 clamps.
RonR
1970 340 Duster
1951 Farmall Super A
Re: V Band Clamps or Band Clamps
moparguy #1413080 Tue Jun 08 2021 12:09 PM
What about just using regular muffler clamps?
I used those a lot way back when and they worked fine.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
moparguy #1413092 Tue Jun 08 2021 01:28 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
The TV “Mechanic” shows seem to favor the V-Band clamps. They are said to seal better. I have zero personal experience with them.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
2-Ton #1413113 Tue Jun 08 2021 04:00 PM
Don
Don, agree on U-bolt style clamps working for their designed job. That being clamping slip fit pipe. My application involves butt fit sections. I could just weld it all, throw a few full circle clamps in the trouble bag and then If I ever need to drop the tranny, cut the pipe and then clamp it back together. After an evenings pondering, I'm actually kinda liking that approach.
RonR
1970 340 Duster
moparguy #1413149 Tue Jun 08 2021 06:11 PM
There are steel V clamps that are a bit cheaper than the stainless versions.
MNSmith #1413196 Tue Jun 08 2021 10:33 PM
But then the issue becomes getting them off without resorting to a sawzall. The stainless V-clamps on the turbo on my truck are enough trouble to remove.
The bigger question is how many times do you expect to have to remove the tranny?
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
moparguy #1413236 Wed Jun 09 2021 02:28 AM
My deal is a Model A Roadster with a blown V6. I'm going to be doing a lot of engine removal and install before the first fire. And I can't leave the headers behind. It'll be a fair weather car, so the V bands will work well in my situation. Otherwise, the Burb got flanges at the headers and everything else was welded up.
moparguy #1413249 Wed Jun 09 2021 03:23 AM
Kevin said; "The bigger question is how many times do you expect to have to remove the tranny?"
On removing the transmission, I'm going with a different transmission that has a more favorable gear set. I pulled the top and all looked fine and end play on the mainshaft was good. But it's a untested unit so who knows if/when it may need to come out.
I do tend to both over think things and obsess over details at times. Now being one of those times I guess. That said, believe it or not a V8 in a Miata causes exhaust systems to be a bit tight so making a effort to get it right first go. The old system was pretty hacked and patched up, hence the extra thought and effort this go around.
RonR
1970 340 Duster
Moderated by  Bouncer, Justhorsenround
