The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (DennisM, fonz8261, Bob Kirk, DJMTruck, Bluesky54, 5 Window 9434), 125 guests, and 4 robots.
Forums60
Topics124,615
Posts1,005,768
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
How to drain and refill my rear ('57 Panel)
#1413047 Tue Jun 08 2021 01:04 AM
I see a square plug on the rear differential, I'm guessing that's how I drain it. My questions are:
1. What oil type goes in it
2. Is there a fill cap on the top somewhere?
Thanks!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Re: How to drain and refill my rear ('57 Panel)
pan3lman #1413054 Tue Jun 08 2021 02:15 AM
AD Addict
The plug your seeing is for filling. You drain it by loosening and prying open the bottom of the cover. Once drained, remover the cover, clean out the gunk on the bottom. Inspect or replace the gasket , then reinstall the cover.
Fill to the bottom of the fill hole. I use 90 weight multi-purpose gear lubricant. If you have a posi rear I believe you will also need some type of additive.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
pan3lman #1413064 Tue Jun 08 2021 04:25 AM
You MAY be able to drain the differential by removing the lowest bolt from the cover. That works on a 47-55.1 1/2 ton. If that works, there's no need to mess with the cover gasket.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
pan3lman #1413077 Tue Jun 08 2021 11:34 AM
Thanks, guys!
Isn't there some letter/number combo on the differential to tell me if it's a posi? Or do I have to just jack the thing up? Dang Frankenstein projects grin
pan3lman #1413082 Tue Jun 08 2021 12:20 PM
AD Addict
That would certainly be the easiest way to tell. If you can find some numbers on the rear, post them and I’m sure our collective will be able to tell you what you have.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1413098 Tue Jun 08 2021 02:33 PM
Will do- thanks!
pan3lman #1413111 Tue Jun 08 2021 03:51 PM
I ran out and quickly checked the sides of the carrier, no numbers found yet but on the left (driver) side are 3 horizontal lines, and on the right (passenger) side are 3 vertical lines. I'm going to look at the base of it within the hour.
pan3lman #1413120 Tue Jun 08 2021 04:10 PM
Can't see the numbers. I'll have to wait until after work when I can get some grungies on.
Moderated by  SWEET
