The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (james1961), 110 guests, and 3 robots.
Forums60
Topics123,939
Posts1,000,194
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Fan blade bolts 1954 Chevrolet 3600 use lock washers?
#1412814 Sat Jun 05 2021 11:33 PM
Dusty53 Offline OP
When I removed the fan blade, it did not have lock washers or any washers for that matter on the 1/4 -20 bolts that fasten the fan blade to the water pump shaft/hub. What is the correct method? Standard Lock washers? External teeth lock washer?
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: Fan blade bolts 1954 Chevrolet 3600 use lock washers?
Dusty53 #1412819 Sun Jun 06 2021 12:09 AM
Any locking device on a 1/4-20 bolt should work. A drop of blue Loctite would probably be my choice, either with a SAE flat washer, or none at all. Be sure to use at least a Grade 5 bolt- - - -the silver-colored Grade 2 bolts found in the usual hardware store bulk bins are soft as butter and won't take much torque. They're good for attaching sheet metal parts like oil pans and valve covers, but not where there will be some noticeable stress like holding the fan on.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Dusty53 #1412837 Sun Jun 06 2021 03:09 AM
Dusty53 Offline OP
Thanks Jerry! I had not considered the grade of bolt or the torque. I'll be sure to get the correct torque spec and get out the torque wrench. Somewhere within the last 67 years the fan blade got changed . Its a 4 blade, 18" but has a 1 -1/8 " pilot hole, not 1" to match the water pump shaft. I'll be replacing it with the correct one. Thanks again for the help.
Ronnie
Dusty53 #1412840 Sun Jun 06 2021 04:02 AM
That constant pull of the fan against the bolts, and any misalignment of the fan to the hub caused by the oversized hole in the fan could set up just enough of a vibration to stretch or loosen an incorrect bolt. Getting a fan blade into a radiator is annoying- - - -losing a single blade due to stress cracks caused by vibration can be downright deadly! I've seen a few destroyed fan shrouds, and at least one perforated hood caused by a fan blade coming adrift!
Dusty53 #1412990 Mon Jun 07 2021 05:10 PM
If got a small mark on the frame from loosing a blade in the late '70s, lucky it went down & not up! Shut it down quick, vibrated like crazy.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Moderated by  Woogeroo
