Stovebolters; I am planning to go to a hydroboost configuration for my 52, 3100. I am looking for a firewall mounted, forward mount, brake and clutch assembly that would have an appropriate brake pedal ratio for power brakes (somewhere in the 4.x to 5.x ratio rather than manual ratios of around 6:1. I am aware that we can modify pedal assembles to change the connection point of the master cylinder to achieve desired ratio, so if that is your experience base, I would also benefit from your wisdom on this topic, but I would prefer to purchase something that is not out of place with the electronic throttle pedal matched to the LS3 under the hood. As an example, when I was planning on a manual braking system, I was targeting Wilwood 340-14360 for a brake/clutch assembly. As Always, thanks for sharing your experiences around this topic.
