The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (68ironhead, 32vsnake, Gone, cmayna, coilover, 5 Window 9434), 154 guests, and 4 robots.
Forums60
Topics125,015
Posts1,008,932
Members45,121
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Speedometer question 49 3100.
GradyB #1412886 Sun Jun 06 2021 07:00 PM
I also think that rear bearing support is held in place by a small bolt on the top of the transmission or maybe on one side of it. I'll look to see if I have anything on this in my old notes.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
GradyB #1413487 Fri Jun 11 2021 01:11 AM
GradyB Offline OP
I have had a chance to pull the driven gear from the side of transmission to inspect it. It shows a couple of miner nicks but nothing major. The teeth look ok. Is the rear bearing support located in the transmission? Not looking forward to taking all that apart again. I haven't driven it since its been inspected but will this weekend. Thanks for all the support. I will figure this out, sometime.
GradyB #1413896 Mon Jun 14 2021 08:03 PM
GradyB Offline OP
Took truck for drive and speedometer still does the same thing. I think too it has to be something inside that's not correct. It works somewhat ok until everything gets up to temperature. Then as I step on gas speedometer goes to zero. If I let off it jumps up to correct speed. Guess I'm gonna have to take things apart.😬
GradyB #1413979 Tue Jun 15 2021 02:32 PM
This sure is an odd one. So when cold, if you step on the gas, the speedo works?
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
GradyB #1414113 Thu Jun 17 2021 01:06 AM
GradyB Offline OP
No when I step on gas it goes zero, quits working. As I let off and coast it goes to correct speed.
GradyB #1414114 Thu Jun 17 2021 01:07 AM
GradyB Offline OP
When cold it works about 1/2.
GradyB #1415486 Thu Jul 01 2021 02:14 AM
Well when you see red and blues, let off da gas, and youll know if they're after you. ohwell
Page 2 of 2 1 2
Moderated by  SWEET
