The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 118 guests, and 3 robots.
Forums60
Topics123,939
Posts1,000,194
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
inner to outer cowl divider
#1412793 Sat Jun 05 2021 06:45 PM
Now that I finally got my inner cowl fitted and welded in, I need to move on to the big divider that goes between the inner and outer cowl panel. I looked at the info in the FAM, and it looks simple enough, that is until you put the piece up against the rocker and inner cowl. It's pretty obvious that this piece fits as bad or worse than the inner cowl did. Since you guys helped me so much on the inner cowl, I thought I'd check with you for hints and tips on this next piece, which I would call a seperator or divider. I assume that the first step is to bolt it up to the rocker, and then to figure out how to get it up against the inner cowl. Any tips or suggestions will be most appreciated.
Re: inner to outer cowl divider
Mike Burns #1412802 Sat Jun 05 2021 09:32 PM
In my mind, with all the fitment problems people have, the most important thing is to make sure that outer panel lines up correctly. So it didn't bother me that my inner to outer cowl panel piece didn't fit the greatest. Especially since it spends most of its life hidden from view.
Mike Burns #1412805 Sat Jun 05 2021 09:59 PM
I agree with Mark
I hacked my repop inner-to-outer cowl pieces to match the outer cowl and the kick panel. In some places, I needed to add material and in others, cut it away.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Mike Burns #1412821 Sun Jun 06 2021 01:28 AM
Are these in between panels that bad .maybe worth trying to make up if they are going to be cut up to make fit .
kevinski 1954 GMC 9300 Welcome to the virtual Garage
Mike Burns #1412826 Sun Jun 06 2021 02:11 AM
The aftermarket inner-to-outer cowls are awful. They do have enough sheet metal in them to make a good one out of. Cutting and welding required.
It would be very helpful to have enough of whats left of the old one in hand so that you will know where to reshape it to fit.
Mike Burns #1412831 Sun Jun 06 2021 02:35 AM
My new inner to outer piece was so bad that a friend of mine actually took my old rusted out on and little by little "remade it". I threw the new one in the trash can.
...yep, "beat them into submission".....I actually learned that phrase from someone else when doing my inner to outer. Patience, patience, patience. Walk away if you have to and come back later. You can do it.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Moderated by  HandyAndy, klhansen
