The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Hello there ...
We have a request from "Harold46".
Curious?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (delky, ChucknPat, Achipmunk, DavidBraley, destryridesagain, 2 invisible), 186 guests, and 6 robots.
Forums60
Topics124,017
Posts1,000,886
Members44,813
Most Online1,229
Jan 21st, 2020
Image Posting Policy
56' 3100 Chevy drum brakes
#1412438 Wed Jun 02 2021 11:23 PM
Moderated
I have a question about brake shoe size for my 56' 3100 Chevy. Factory spec. for the front shoes is 11" x 2" and 11" x 1-3/4" for the rears. Could there be issues using the larger 11" x 2" shoes on the rear? Half of The feed back I've got from other truck owners and the vendors is mixed. Napa sent me 11x2 shoes for both ends. Should I keep them or get the 11 x 1-3/4 for the rears?
Thanks for the advice.
Anthony
Re: 56' 3100 Chevy drum brakes
Anthony B #1412441 Thu Jun 03 2021 12:23 AM
First, I don’t think the anchor pin at the top will be long enough for the wider shoes to come against.
Second, making the rear brakes more powerful is dangerous. If they are, they are likely to lock up on a hard braking situation and send you into a tail spin.
My Blog
Anthony B #1412495 Thu Jun 03 2021 02:41 PM
The 1 3/4" shoes are correct for 51-57 trucks. The backing plates were changed in 58 to use the 2" shoes which carried through the 60's. I would stay with the correct shoes for your year.
Fred
Anthony B #1412530 Thu Jun 03 2021 05:26 PM
To use the 2" shoes you will need the later backing plate and drums. NAPA should not have sent you the 2" under any circumstance. If you have a local store, they should have a source to get you shoes relined.
Fred
52 3600
69 C-10
Anthony B #1412538 Thu Jun 03 2021 06:37 PM
Moderated
Thanks for all the advice on the brake shoes. I will return them and get the correct size.
Anthony B #1412540 Thu Jun 03 2021 06:56 PM
Moderated
Moderated by  SWEET
